Haven 220
Haven 3" Lift - Considering a three inch lift for our Haven to give us a bit more clearance.  Performance Trailer Braking offers a kit and a mobile service option.  Cost me around $600, but I was curious as to whether Nucamp has noticed the issue and is already looking at a modification.  Well, in response to that question, I got this reply "I had to reach out to our leadership and tech support to check on this. They advised that they are currently working on a prototype with 32 degree pitch, after positive test results this could be scheduled to install. So we will keep you updated!".  Since that exchange, I haven't learning anything else.  So, I'm not sure if this is a modification or if this is something they are looking at for the later 2026 or 2027 models.
Haven 220
2026 Ford F150 Tremor 5.0
Niceville, Florida
  • lino
    lino Member Posts: 246
    edited April 19
    Im curious if this is related to reports of the back bottoming out? Or maybe just more off road clearance?
    i’ve seen videos or read about the trailer bottoming out and some brace underneath which would be a concern to me
  • Blueespy
    Blueespy Member Posts: 288
    I think part of the issue is the two upside down triangles that are bolted under the frame near the back.  I'm sure the intent was to keep the back of the trailer from rubbing, but in our opinion, they are too long.  We did confirm they are bolted on, so one thought was to unbolt them and then shorten then a few inches.  Another is to install a Torlfex Lift Kit designed for a single axle.  This would give just short of a 3" lift.  There is room in the wheel well for larger tires but it would be expensive as you would need tires and rims.  Our Haven has an appointment at the factory in May for some work and the 32 degree pitch is on our list for the factory.  Since nucamp is radio silence we're just going to have to wait and see.
    Haven 220
    Niceville, Florida
  • lino
    Thanks for the information
    I’m at least a year away from being able to purchase a new camper but currently this is on the top of my list.
  • Blueespy
    I "believe" nucamp is working a prototype pitch axle for the Haven. When I spoke to their rep at the rally in April he said the testing was done and he would know more soon. We are scheduled to have some repairs on our Haven at the factory 25 May and on our shop list is a lift/pitch axle if available. If it happens, I'll post before and after pictures here.
    Haven 220
    Niceville, Florida
