Broken Plastic friction piece.
Hi there- I've got a broken plastic friction piece for the shade on the stargazer window. Does anyone have a bush fix/repair recommend.
Photo, attached. Thanks
Mark
  • vhollow
    vhollow Member Posts: 100
    I did a bush fix (nice term). I cut a corner off a plastic wall outlet cover plate. I drilled a tiny hole and screwed it to the window glide. Then I built it up to sort of match the other side using Scotch tape as a frame mold for JB Weld epoxy putty. I made grooves for the cords to keep them in place and to reduce friction. A bush fix. Amazingly, it worked!
  • jimcenname
    jimcenname Member Posts: 348
    FYI these people supply spare parts for the blinds. I bought string and other parts from them. Slow and expensive but they were the correct parts that worked well.
    Dan Rodabaugh (574) 596-9100
    Karmen Bracun <karmen@euro-rvparts.com
    2019 T@B400
    Southern California
    Full-timer since 2019
  • markfels
    markfels Member Posts: 2
    Thanks for the suggestions!
