Tongue Jack Replacement advice needed.
Havedogwilltravel
Member Posts: 2
I have a 2006 Tab that needs a tongue jack. It looks as if the original was inside a round slot in the V of the frame. The current one is a bolt-on to the side of the frame, which has bent the frame a bit. Looks like it may not have been the proper side bracket. Is there a replacement for the original center jack, and is it possible to bolt or weld it in place? Doesn't look like much surface room for that, or is the outside/one-side of frame with a proper bracket sufficient? Any advice would be greatly appreciated.
This thread shows the two types of jacks you are describing.You may have to dig a bit to find a replacement, some of these threads are fairly old. But, the parts are out there.This thread has more info.
Towed by 2014 Touareg TDi -
They're call a "jockey Wheel" in the UK. Alco is the brand you want. https://www.towingandtrailers.com/product/caravan-motorhome/caravan-parts/caravan-jockey-wheels-2/alko-48mm-pneumatic-caravan-trailer-jockey-wheel/
Romana - 2005/6 Thor T@B T16
Port Townsend, WA -
Thanks so much. Managed to get it repaired.
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
