Thanks
qhumberd
Moderator
Thanks
qhumberd
Moderator
Isotherm Intelligent Temperature Control
stepheng
Member Posts: 128
Has anyone installed this on their refrigerator? Would be nice to just set a specific temperature and forget it.
2022 T@B 320S Boondock
Would be better than having to reset the temp control after you turn the fridge off every time. I leave a remote temp sensor inside to monitor it. I'm thinking I might just put an external switch on the fridge power so once I have it set I can use the switch to turn it on and off so I don't have to reset the temp control each time. Would be cheaper but might not make the fridge more efficient as they claim the ITC would.2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York -
Is it weird these refrigerators don’t just have this option built in like a normal household refrigerator? It’s like older cars that don’t have a temp control for their climate control. Even low-end models of cars have temp control.I do as @SLJ does and put a cheap Bluetooth temp sensor in the fridge. You can set alerts for when it the temp goes too high.2021 400 BD
2020 Tacoma TRD Off-Road -
I use a bluetooth temp sensor as well but I have to adjust dial thermostat as the temp varies based on where we are and inside/outside temps2022 T@B 320S Boondock
Think I'm going to do this mod. Has anyone removed the Isotherm Elegance 65? If so I would appreciate the details.2022 T@B 320S Boondock
- 916 Introductions
- 72 Teardrop Groups & Links
- 913 Tips & Tricks
