new format == Location of Mark All Read command ?
Thanks @MuttonChops. That function is turned on, but does not show up at any level so I have elevated that to Vanilla for an answer. Should be an easy fix for them. the other thing is the signature size and font. Some folks may have to resize it as mine was WAY too big. Yours looks fine in this thread
Still working on this but at present you have to mark EACH category from the main category list as Read:qhumberd said:Thanks @MuttonChops. That function is turned on, but does not show up at any level so I have elevated that to Vanilla for an answer. Should be an easy fix for them. the other thing is the signature size and font. Some folks may have to resize it as mine was WAY too big. Yours looks fine in this thread
This is not very easy and requires you to check each category. So still working on it...
Interesting . . . I only see a 'mute' whatever that means option
This isn’t about that, but I don’t really wanna dig. I just wanna complain that I do not like gray Text. I wish it was black. I’m too old to read this lol I even turned my screen all the way up.2019 Custom T@B 320 U Boondock Lite-ish
We've slept in 34 states, 2 countries & counting1 -
I agree and the Vanilla folks are working on the text and contrast issues so I will remind them and see if we can get that improved.ColleenD2 said:This isn’t about that, but I don’t really wanna dig. I just wanna complain that I do not like gray Text. I wish it was black. I’m too old to read this lol I even turned my screen all the way up.
This new theme was aimed at a demographic best described as "not me"2019 T@B 400 Boondock Lite towed by 2016 5.7L Toyota Tundra
3 -
Yep they are working on stuff so it is surely stirring up the gremlinsMuttonChops said:Interesting . . . I only see a 'mute' whatever that means option
Hopefully we won’t be chasing this too long2019 T@B 400 Boondock Lite towed by 2016 5.7L Toyota Tundra
Vanilla is adding the Mark All Read option back so that should show up soon in the Quick Links area.
and @ColleenD2 the font was adjusted and seems darker with more contrast and bolding.
Let me know what you think
qhumberd
Moderator2019 T@B 400 Boondock Lite towed by 2016 5.7L Toyota Tundra
Here is the answer on Mute...MuttonChops said:Interesting . . . I only see a 'mute' whatever that means option
Mute Posts
ByTroyLast Updated:Feb 5, 2026As a member of an online community, you'll likely Follow and engage with numerous posts from other users, not to mention create your own posts that others engage with. Over time, you may come across threads that produce a high volume of engagement that you're not interested in, and this engagement can result in a similar high volume of notifications that flood your inbox.
To mitigate frustration in such scenarios, Higher Logic Vanilla (Vanilla) includes the Mute Posts feature that allows you to stop receiving notifications for specific posts, without unfollowing Categories, removing bookmarks, or turning off post notifications as a whole. This feature is designed to reduce unwanted notifications, especially from busy or "chit chat" threads, making notification management more granular and user-friendly.
Did "Vanilla" give a completion date for the Mark All Read or improved text contrast fixes?I don't "see any" change and would have expected updates to be completed nightly.Am a bit surprised that the New 'Standard' Format is sooooo poor as Vanilla PR Pages suggest "it" has been in usage for a long time and is loved . . . .
So the Mark all Read option was apparently only popular with a few folks, or maybe only you and me. It is now only on the Home page, which I edited so show as Home in the title bar.MuttonChops said:
Go here for that
https://tab-rv.vanillacommunity.com/
You should see the widget on R lower column. Let me know if other wise
So the routine for me is Home page to look for new posts, then the Category page to look for recent posts by category, then the Discussions page for anything else. I think it all works now
I, as moderator made a change to the font style that created bold sections and made the text a little darker. Seems easier to read but if not enough I will go back to Vanilla. It is really not a Vanilla problem as much as a "me" problem trying to learn the forum options and being a bit overwhelmed with the jargon2019 T@B 400 Boondock Lite towed by 2016 5.7L Toyota Tundra
Thanks, I found it and it worked.qhumberd said:
. . . Mark all Read option . . . now only on the Home page,
I didn't read/follow the Vanilla text/link
I just need the Button Location
Can't really believe You & I are the only folks that use Mark All ReadI'd never be able to read any forum if I couldn't just delete several days of 'stuff' when I login.
I use the Mark All Read option and appreciate having it restored.
Scott / 2019 T@B 400 / 2015 Chevrolet Tahoe LTZ / Northern Illinois
I have found the Javascript options and moved the font color more to the dark end. Seems still better on my screen but the options were not really labeled well and I am trying to make incremental changes so I don't make stuff go invisible...ColleenD2 said:This isn’t about that, but I don’t really wanna dig. I just wanna complain that I do not like gray Text. I wish it was black. I’m too old to read this lol I even turned my screen all the way up.
Let me know if we are where we need to be on contrast and readability.
qhumberd2019 T@B 400 Boondock Lite towed by 2016 5.7L Toyota Tundra
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 920 Tips & Tricks
