Need Advice on Changing Out Rear Taillight on 2015 360s Boondock - Resolved
michaelroyy
michaelroyy Member Posts: 58
This is a new post following my 7-pin plug issue. I think I traced it to a rear taillight. My new problem is that the taillight does not just pop out. I took off the small plastic housing, pulled the taillight out, pulled the junction box out, and it looks like the wiring goes further into the housing. I have attached (4) pictures that show, hopefully, my dilemma. Two questions: 1) do I have to take off the whole back-end plastic or am cutting and splicing? 2) where can I get a replacement for the rear light?
2015 Boondock
    pthomas745 Administrator, Moderator Posts: 4,685
    There have been several threads about LED replacement tail lights in the past.  Try this to start, which has a part number for the "Kaper" II.
    This thread has the same link embedded in a comment, but there are also pictures of the install.
    And, here is another I just stumbled across.
    There may be some differences in various years, of course, compared to your 2016.  But the part and process should be close to the same.
  • michaelroyy
    thank you for all of your help; I ordered a set of replacement taillights, and I have my fingers crossed that they will end my saga of no right turn signal that started as a 7-pin issue
    2015 Boondock
  • michaelroyy
    For my 2015 Boondoock:
    I followed the suggestions made Thomas and went to superbrightleds.com. I ordered the: Round LED Truck and Trailer Lights Combo Box with License Plate Light - 4" Stop / Turn / Tail Lights - Universal Stud Mount 9 LEDs; SKU: TLS-R17HF-R-K.
    They worked when I test wired one of them. Three things that I learned: 1) there are two bolts with washers that keep the junction box together. I needed to cut down both bolts because they were too long to fit into the taillight housing (attached photo). 2) I needed to cut the wiring from the old taillight to wire the new taillight. No plug-ins… I soldered, heat wrapped and taped the (3) sets of wires together; and 3) I needed to use a silicone adhesive to keep the junction box snug/attached to the taillight housing (attached photo). Without this, the taillight junction box will move around.
    2015 Boondock
