Ceiling molding
Has anyone else had the ceiling molding retract? If so, how did you repair it?0
Just push the molding piece back over. While traveling, it has a tendency to move. You could put a bit of adhesive in the crack before moving it.
Ken / 2023 Tab 400 “La Bolita” (39,000+ miles) / 2024 Toyota Sequoia1 -
Hmm I have the same problem! Why did they not just put a piece the entire width of the trailer that way there would be no movement? The molding can't be that expensive!
Just to add to this discussion for anyone with the same issue, here is a similar discussion:
https://tab-rv.vanillacommunity.com/discussion/comment/202160#Comment_202160?utm_source=community-search&utm_medium=organic-search&utm_term=ceiling+strip
Greg & Marlene (Tucson, AZ)0
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
