Galley Door hinges for 2020 Tab 400 Boondook
Trooper
Trooper Member Posts: 10
edited May 19 in Teardrop Groups & Links
I just purchased a 2020 Tab 400 Boondook. There were only two obvious problems with the unit. The batteries needed replacing and the door hinges on one door under the galley sink are damaged. Replacing the batteries was easy. And I thought the hinge issue was going to be easy as well-NOT. I can't find a replacement hinge. The hinges on the newer units are not the same as on mine. Nucamp is no help and the local dealer is not able to give me the correct hinge.
The old hinges are marked "HR" which I believe is Hardware Resource. There is also a stamped "V45" on the hinge.
Does anyone here have any advice?
TIA
PS We love the trailer.
2020 Tab 400 Lite
2025 Hyundai Palisade
Tubac, AZ and Alpine, AZ
  • rfuss928
    rfuss928 Member Posts: 1,196
    Will these work?
    https://www.ebay.com/itm/116913262720
  • Trooper
    Wow, my search is over. Thank you.
    2020 Tab 400 Lite
  • Trooper
    Well I purchased the hinges from ebay and they don't fit. The ones on ebay are not the same hinge. Back to the drawing board. BTW, I am very disappointed that Nucamp can't be more helpful :(
    2020 Tab 400 Lite
  • GregR
    GregR Member Posts: 20
    Trooper, I have four (4) HR V45 hinges you can have. Message me with your mailing info. (These are from the curved cabinet doors under the galley sink in my 2022 400. My doors warped and I replaced them with 1/4" alum. diamond plate with continuous (piano) hinges.)
    2022 T@B 400 BD, 2018 Toyota Tundra, Palisade, CO
  • Trooper
    Gregg, Do they look like these? All of the hinges I have seen don't have the offset as seen in the second Picture.
    2020 Tab 400 Lite
  • GregR
    Yes. And all four have the "V45" stamped at the top of the back of the "cup" like the first picture and "HR" stamped in the bottom of the "cup".
  • Trooper
    If you could mail them to PO Box 1131, Alpine, AZ 85920 I would really appreciate it. Let me know how much and I will send a check or Zelle you the money.
    I wouldn't mind getting some of the Palisade peaches as well 😀
    2020 Tab 400 Lite
  • GregR
    They're in the mail and you should receive them in about 4 days.
    You owe me nothing. (As Jimmy Buffett sang, "Someone wants a piece of you, never let them pay. What you do not give them, time takes anyway.)
    Unfortunately, it's a little early for peaches.
  • Trooper
    thank you so much. I am happy to pay for shipping. 👍
    2020 Tab 400 Lite
  • GregR
    I appreciate the offer, but no thank you. You needed the hinges and I needed less stuff in my garage. That's a win-win in my book
