Wheel Bearing Parts - 2006 T@B with ALKO Axle
I need to find parts for the wheel bearings on my 2006 T@B. The axle is an ALKO brand with a special one use lock nut that holds the wheel on the axle. The bearing is press fit into the wheel hub. Where can I purchase these parts? The information on the axle indicates it is Type: B 850-3, BN:20, A: K5024121
There is a thread with some discussion on the brake system and bearings.
https://tab-rv.vanillacommunity.com/discussion/comment/146566#Comment_146566
This link seems to still work for the bearing kit::
https://www.ebay.com/itm/Caravan-Trailer-ALKO-Euro-Bearing-Kit-641551/373053522746?hash=item56dbb9033a:g:NT0AAOSwL01evqHA
The magic numbers for these sorts of things are "Alko 1637" , which is the axle and hub assembly, and SKF GRW120, which is the bearing.This thread, from 2020, goes into specific detail. Whether or not NuCamp still has these parts in stock I sort of doubt, but apparently they are still in stock from various sources. I know the bearings are easy to find in the US, but it seems things like the axle parts may be a bit more difficult to find in the US.
Thank you so much. I had checked with numerous bearing suppliers and was quite frustrated by their lack of knowledge on how to cross reference that bearing. All I need now is a source for the locking nuts.
Thanks again. You saved our trailer!
Always happy to see a DM on the road!
This group has an extensive Dutchman Archive.
Towed by 2014 Touareg TDi0
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
