part numbers for 2025 Tab 360 Boondock/Black Canyon bearings and seals
levbob
levbob Member Posts: 27
want to carry replacement wheelbearings and seals for 2025 Tab 360 Boondock/BC, does anyone know wheelbearing ans seals part numers and manufactirer?
Thanks.
  • Grumpy_G
    Grumpy_G Member Posts: 784
    Any bearings+seal kit for a 3500 lbs Dexter axle will work, there's nothing special about them. I got mine at an auto parts store because I needed the seal right then.
    pthomas745 Administrator, Moderator Posts: 4,684
    This thread has a lot of information on the kits, with various links to Dexter, etc. Try the last two pages.
  • levbob
    not sure of part numbers for Dexter stuff
    Is the Tab 360 Boondock brake size 10” x 2 ¼”. So spare magnet is Dexter kit K71-104-00?
    Does the Tab 360 Boondock use standard of EZ Lube Seals?  Seal kit K71-303-00?  (which is for 10” x 2 ¼”)
    Which brake show replacement kit is correct?  K71-047-00?
    Which bearing replacement kit?   K71-390-00 inner bearing  for 10” x 2 ¼” 3.5K axles, K71-306-00 for outer bearings?
    Cup/cone LM67010/LM67048?
  • Mseilstad
    Mseilstad Member Posts: 1
    I am also looking for the seal part number. Tab 320, 2018 Thanks.
    There are a number of Bearing Maintenance Threads, and on page 4 of this thread there are various kits mentioned.
    Bearing Maintenance
