Improved Performance for TAB 360 fridge
Hi,
If the fridge in your TAB 360 (or really any RV fridge of this style) struggles in warm weather, I wanted to share a modification I made that dramatically improves performance when cabin temperatures climb. I’ve tested it with extreme interior cabin temps reaching 100°F, and the results show the fridge can now maintain low‑30s throughout, even the top drawer. I’ve included data below showing the improvements.
Background
The fridge/freezer works very well until the cabin temperature rises above ~75°F. But once the interior warms beyond that, cooling performance drops off sharply. Running the cabin Saphire AC solves the problem, but that’s not always possible — especially when boon docking or driving down the road in summer, when the cabin heats up. Also, if you never camp in warmer weather, the issue won’t be experienced.
There are a few tricks that help somewhat:
  • Keeping the vent below the freezer open
  • Avoiding blockage of the rear open space inside the freezer
  • Removing the glass shelf above the top drawer
But in hot conditions, these alone aren’t enough. Some people rotate frozen water bottles from the freezer to the fridge, but that’s a hassle. And the bottom drawer will never cool well because the top-drawer blocks most of the cold airflow.
After digging around online, I found many RV owners with this same fridge reporting the same issue.
Cause
This fridge is relatively tall, and all the cold is produced in the freezer at the top. Without an evaporator fan (which every home fridge has), very little cold air makes it down into the lower fridge section. As a result, the upper area cools somewhat, but the lower shelves and drawers stay warm.
Solution
As shown in the photo, I installed a small computer‑style fan in the freezer to push cold air downward into the fridge compartment. I paired this with a second small fan inside the fridge (mounted low in the upper drawer) to improve circulation.
Together, these two fans have made a huge difference. Over the past week of very hot weather in my area, with the cabin getting extremely warm, the fridge has consistently held to the low to mid 30s F, everywhere, except the bottom second drawer. The data below shows the test results.
Installation Notes
  • The fridge has an existing hole sealed with non‑hardening putty that can be used to route wires to the rear compartment. Just push the putty aside and press it back afterward.
  • All 12V connections can be made using the existing 12V outlet to the left of the fridge or the same connections (as the OEM fan) at the bottom of the rear of the fridge.
  • The modification is fully reversible and doesn’t require altering the fridge’s structure.
Additional Improvements: Insulation + Rear Ventilation
To support the internal airflow upgrades, I also made two additional changes to the rear compartment:
  • Added batt insulation behind the fridge, plus a thin layer of insulation on the right side. The fridge cubby gets extremely hot when the trailer sits in the sun, and reducing heat soak helps the cooling system keep up.
  • Upgraded the rear ventilation fan to a larger, more powerful unit. This helps create a stronger chimney effect, pulling hot air up and out of the rear compartment more effectively.
These rear‑side improvements help, especially in direct sun, but the freezer fan + interior circulation fan remain the dominant contributors to the improved performance.
Hope it helps other…
2025 360 CS
Southern Maryland
  • Gomers2
    Gomers2 Member Posts: 172
    Well that looks pretty slick. Can you say more about the batt insulation product you used, and how you attached it to the curved backside of the camper?
  • Yoshi_TAB
    Yoshi_TAB Member Posts: 597
    Hi, It was "standard" attic insulation because I had a small piece available around the house. Not sure of the R value. It was a bit tricky to get it to stay in place, but I had some gorilla tape that worked. It's behind the fridge so looks was not important. I found (at Home Depot) some very thin heat barrier with a small R value to use on the right side. As you know, there is only about 3/8 " of a gap.
    I have a thermometer gun and was surprised how hot the wall behind the fridge and the right wall was in the direct sun. But as I mentioned, although I have no data t support this, I beleive the fans dominant the results.
    I and a few others also have placed heat barrier directly on the rear panel of the fridge. We were thinking heat from the compressor and rear coils were conducting through the back wall of the fridge and into the food area.
    2025 360 CS
    Southern Maryland
  • Trailpixie
    Trailpixie Member Posts: 205
    This looks like something I need. Great work! how long have you been able to run on the lithium battery alone? what refrigeration temp setting are you testing with?
    thanks
    (previous 2018 T@B 320 Outback, 2021 Jeep Grand Cherokee V6)
    Maryland
  • Yoshi_TAB
    edited July 6
    Hi @Trailpixie
    I just completed a second set of testing before a 3-month trip we are starting in about week. It was run on battery in full sun. I don't have any data to provide to determine how long it will run but I did not observe any increase in battery consumption from the additional two interior fans. Their consumption is small. IMO, overall battery consumption will be less because the compressor running less to keep the fridge cold.
    I ran the testing on setting of both 4 and 3. On a setting of 4, the freezer ran 4 F and the top shelve was a bit cold at 24F. The upper drawer was at 35F, the interior of the TAB was 110F
    On a setting of 3, the freezer ran at 13 F and the top shelf was 32 F and the upper drawer was 42 F, with an interior cabin of 107F
    These were extreme tests (hot in the TAB) to demonstrate to myself that the addition of the freezer fan and lower fan is keeping the fridge cold (except lower drawer) as it should.
    The challenge will be to regulate it (either with fridge setting or fan on/off) so the top shelve is not too cold. I have a toggle switch for the freeze fan so it can be turned on/off. But I rather have it too cold and play with the setting rather than to have the fridge be warm inside when the cabin is warm/hot.
    The bottom drawer is completely useless as the temp rose to the mid 50s. Again, the reason for this is because the compressor is right behind it, and the heat is coming through the fridge wall.
    BTW..what part of MD do you live ?
    2025 360 CS
    Southern Maryland
