Adding 12v Connection for Starlink Mini: which side of trailer? (need opinions)
For a 2025 tab 320 BD
I'm going to add a 12v connection for my starlink mini. I am waffling on which side of the trailer to add it on. Let me know if you see me doing anything stupid…
Passenger side: I can wire directly to battery/bus with inline fuse, run line to rocker switch mounted near battery cutoff (or anywhere along bottom of dinette seat base), then drill hole in side of trailer for bulkhead port. Sounds easy, shorter wire runs, port located next to outdoor power outlet.
Driver's side: Wire into fuse box, mount rocker switch some where along base of dinette (would love to mount it up near stereo, actually) and have bulkhead connection located in the Nautilus (P3) compartment (where coax, etc. already are). I am thinking I'd use the hole for the black tank flush since I don't have a black tank and there's just a dummy plug there now.
If I decide to tie into fuse panel it'd much easier to use a piggy-back fuse, but that seems a little too DIY to me, any thoughts on this? If I splice in from the back does anybody have any pics of what they've done in the past? (I am more of a visual learner.) I don't think the fuse panel has any spare slots does it.
So here's what I am looking at getting (any input on this is welcome too):
Rocker Switch
Bulkhead Port
12v Adapter/Step up
2025 Tab 320 S BD
2024 Nissan Frontier
  • mx4789
    mx4789 Member Posts: 72
    So, I finally got around to working on this project….
    I decided to install it on the driver's side. I liked the idea of having the bulkhead pass through port mounted in the Nautilus where it'd be more protected from the weather, and I wouldn't have to drill a hole in the body of the 320. I popped out the dummy plug for the black tank flush connection and and clipped off the plastic retaining clips located on the back side of the Nautilus. Then I only had to do a minimal amount of filing to enlarge the existing hole enough for the port to fit. A dremel tool made short work of it.
    I got a rocker switch so I can control the power to the dish from inside the camper without having to unplug anything. I wanted to mount the switch up next to the radio, but that would have involved more logistics than I was willing to deal with (ie, too much dismantling other unrelated stuff just to make it happen). I though about mounting it down low next to the power converter/fuse box, but I didn't want to be on my hands and knees trying to cut out an opening for the switch while dripping sweat everywhere. And I'm glad I didn't because once I lowered the dinette seat I realized the seat legs (that pull out when you make it into a bed) would have covered up/interfered with the switch.
    Instead, I ended up mounting the switch in the microwave cubby which I use as an open overhead storage compartment. I chose this location because that's where my cell booster is mounted, the switch will be less prominent in there (I like the cool blue light, but probably not at night though) and there's an access hatch I could take off for easy access to run the wiring down to the electrical area. This also meant I could take the access hatch over to a workbench and take my time getting a square cut into it for the switch that would be, well, square (straight, level).
    After the switch was all "squared away" I ran a fish tape down the space in the bathroom wall and it came out under the wall in the electrical area under the dinette seat. I taped the three wires needed to operate the switch to the fish tape and pulled them up through the wall and was able to plug them into the switch.
    I was originally going to get power by using a piggy back fuse (kind of like an extension cord for fuses) but after taking the face plate off of the converter (or is it inverter?) I realized there was no way to get the wire to the back side without more dismantling of things. So I found a wire for an acceptable circuit (I chose the fan and toilet circuit) and traced it to the spot where it splits off to the different devices.
    NuCamp uses a lever-style quick connect housing for their wire junctions, and I noticed that this circuit had an open bay on it's connector. I simply had to lift the lever up on the open bay, insert the end of the "hot wire" and close the lever back down. Then I loosened one of the screws on the ground bus bar and inserted two ground wires into it and tightened it back down. There was a ground wire for the step up converter for the mini and another ground wire for the switch. All that was left was to connect the power wire (accessory wire) from the switch to the step up converter for the mini and then plug everything in.
    I was definitely on high alert when I switched the battery back on, but no sparks or melting wires occurred and I had power to the dish. This literally took me all day to accomplish. The majority of it was consulting the all knowing google to verify that I was doing it correctly. I think my biggest source of doubt was getting the rocker switch wired since the directions were nonexistent.
    Now I can plug the starlink cable into a power port in the Nautilus when I get to camp, and control the power from inside the Tab via a switch. I like being able to turn the dish on/off without having to run around unplugging things.
    The wiring for the system is connected like this: power from battery positive to switch, power from switch to the mini, ground from mini to battery negative, ground from switch to battery negative. I seems really simple once you've done it, but there was a lot of doubt on my end until I got finished.
    Anyway, just following up on the above post in case anyone else is considering something similar and hoping it helps.
    2025 Tab 320 S BD
  • elbolillo
    elbolillo Member Posts: 575
    edited June 15
    I used the nautilus hatch for my Starlink connection. I installed a 12v converter in order to power my articulating Starlink.
  • valkraider
    valkraider Member Posts: 61
    I am thinking of using the existing 12v wires that ran to the step light - which I disconnected before even camping once - to install a 12v adapter somewhere there on the passenger/camp site side of things.
    But I could also throw a 12v in the nautilus I guess.
    I do already have the solar connector there in the Nautilus - with the (debatable) backwards SAE connector - which I think runs directly to the battery?
  • valkraider
    I made a small lead/adapter with a switch and a 7.5a fuse, which connected to the solar port in the nautilus and has a cigarette-lighter style 12v plug.
    I’ve got the parts coming for the same style plug and fuse to wire in on that step light wiring, and will also use a 7.5a in line fuse - since the lighting circuit is a 7.5a fuse in the main panel…
    I bought a 30v step-up Starlink power adapter which uses that cigarette-lighters style plug - that I can also use in vehicles or wherever, and it is only 3.5a so should work well.
  • mx4789
    Good information to know… I wasn't sure about which one to use so I went with a circuit with a 15 amp fuse, but I was totally guessing at it.
    2025 Tab 320 S BD
  • anba
    anba Member Posts: 30
    @valkraider I just read your post about converting the step light for Starlink. Would you mind explaining in a bit more detail how you did it and what parts/ accessories you used? And maybe a few photos. I‘m not a great DYIer when it comes to electrical upgrades and would appreciate any help.
    Thanks
    2020 T@B400 BDL w/solar | 2022 Ford Expedition
  • Horigan
    Horigan Member Posts: 915
    edited September 14
    @anba, One option is to use this 12V Starlink power adapter, place the Mini on your roof above the door and run this power line into the side window to the 12V socket. That's what we do.
    Starlink Power Cable
    You could also put a 12V connector at the step light power wire and run the above cable to it, but running it through the window seems easier and no wire DYI required.
    Power adapter
    Rich
    2019 T@b 400
    Bellingham WA
  • Grumpy_G
    Grumpy_G Member Posts: 784
    Admittedly this is a different solution but I'm using a small Jackery power station to power the Starlink Mini. This allows me to put it wherever needed, even somewhat far away from the trailer, and not worry about how to run the power cable.
  • anba
    Thanks for the ideas. I’m currently using the Starlink cable into the 12V under the seat. But running it through the door or the window means I either have to leave those open or squeeze the cable. I could install a Starlink pass through but that’s too much for me. The power adapter looks interesting as does the external battery solution. Gives me something think about.
    The funny thing is that even the new Havens from Nucamp have no Starlink connection.
  • valkraider
    edited September 21
    Well, I used some parts I already had sitting around and bought some new ones.
    I had a female 12v outlet and in-line fuse receptical, a 12v in-line switch, and plenty of SAE connectors from 40 years of motorcycle battery tender ownership. ;)
    There exist pre-wired connectors you can buy that go from SAE to 12v female outlets - but they wouldn’t work here because the polarity is backward in the solar port connector on the trailer.
    So I just made my own, the SAE connector here would be opposite polarity that people may expect - so I put a little label on it, added in the switch so I could turn it off when not in use without unplugging it, and added the fuse for good measure.
    I use it with this 30v step-up adapter for Starlink. You really need a step-up adapter like this when using the Starlink off any 12v system because Starlink is incredibly finicky about voltage drops and will reboot itself a lot if your 12v voltage drops down too much - as 12v systems often do. The step-up adapter raises the voltage and keeps it in a range that Starlink is completely happy with.
    This adapter would also work with anything that needs a 12v outlet - but I fused it at 7.5amp so nothing really heavy duty…
  • Horigan
    The sensitivity to 12V voltage drops is why the 12V power cables are only 3 meters long. Having lithium batteries and their higher voltage also helps.
    Rich
    2019 T@b 400
    Bellingham WA
  • valkraider
    True.
    But if someone is going to buy a 12v power cable anyway, I would advise to just buy a step-up convertor and get rid of the concern entirely. They are not expensive, and most of them will just work fine with the regular starlink cable you already have. Additionally, having a step-up convertor is useful for almost any situation as they can be used then with a vehicle 12v outlet, or with a power bank 12v outlet, or with some other 12v power source.
    In an experiment ,I was even able to get it to run off of a suitcase solar panel (albeit - unless you have a pretty powerful setup, it would require perfect direct unbroken sunlight for the whole time, so I usually plug the solar into my power bank and the Starlink into the power bank so that the battery can step in when the solar skips a beat).
  • valkraider
    Also - I have a buddy that has an adapter that lets him use DeWalt batteries to power his Starlink. It works well, and he used it the other day with me for about 20 minutes with no problem. It is a quick and easy way to use a Starlink for a short period… Not really specific to this thread we are discussing here - but kind of a nice way to add another option to power the Starlink Mini.
