Hubs and axle available for 2008 Dutchman T@B
I have a 2008 Dutchman T@B I'm converting to standard hubs and electric brakes. Is there anybody or T@B parts supplier that would want the existing hubs and axle? I hate to discard the assembly, but I have no use for it. It does have some damage (right hub surge brake cable guide is damaged). That's one reason I am replacing the existing axle and hubs, also so I don't have to worry about maintaining the existing AL-KO mechanism. Perhaps it could be repaired, or at least provide spare parts.
I would need to know by June 13, that's when I expect to pick up my modified T@B.
I don't know what shipping arrangements would be needed, can deal with that if someone is interested.
Thanks.
Go ahead and list an ad for free parts under the For Sale category. It may be more visible to those who may be interested.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
I know it is past your do date but do you still have your axel and hubs?0
Hi, I have a standard Tab 320 and need a new bearing/hub assembly for one side. I am considering replacing the axle. I live in Northern Idaho.
If yours is not available, I'm curious what can be used to upgrade the hubs.
Tom W1 -
I am looking for a Left brake Drum. if you have the left Brake assembly I can it also. Hub cast Number is 606260
This Drum has 5 bolt holes and the casting number inside the drum is 606260. this is a small brake drum
