Replacing 2021 320 front window with new version
Since acquisition the front window has had a small crack at one screwhole where the side latch attaches to the plexiglass. This winter it spread and we decided to replace the plexiglass.
Tools: No.2 square drive bit; autobody plastic pry bar and scraper; 1/8" bit to undersized pre-drill; polybutylene caulk and/or tape; naptha for cleanup; rags; stepstool. blue tape and pen; rafter square and tape measure; cardboard for centerline template; magnetic dish for hardware.
Note from factory....We unfortunately no longer carry the window that came with this trailer so they will need to upgrade to our new tinted version, 320 Front tinted window part number 24426 and price $308.99 UPS 2ND Day Air Shipping estimate $48.02 Total - $357.01
Windows are non-returnable due to freight costs and the high risk of damage during transit. Window orders are processed via 2nd Day Air shipments.
After discussion with Nucamp, ordered replacement from via Missouri Teardrop Campers. It was “in stock.” The “factory” (Nucamp) did not process the order for five weeks, without communicating that fact despite inquiries. No explanation. The window arrived nicely packaged with slotted pool noodles protecting edges, bubble wrap, and heavy box.
The top mounting extrusion on original and new window differ markedly.
new- one piece top aluminum extrusion into which window inserts face-on when rotated 180deg upwards, and hinges down into position. Extrusion attaches with countersunk flathead self-tappers.
pic- original two-piece below; new one-piece resting above for comparison. Not in mounting position which was ~5/8" higher than original position.
Removal:
For window and extrusion removal clearance, it is necessary to loosen and lift the upper righthand portion of the black half-moon extrusions over the Tab side/roof joint. I tapped upwards to loosen from rusty clips, and lifted two inches to slide the original aluminum extrusion out.
Unscrewed clasp hardware in window opening, removed top hinge setscrew, slid plexi window off to right.
Then tapped and slid inner aluminum extrusion off to right and out.
Used plastic pry bar to remove aluminum extrusion and to scrape off adhesive caulk tape strip.
Cleaned up Tab with plastic scraper and lots of Naptha on rag, being careful to not flood the rubber seal that might have adhesive behind it.
The self-drilling screws pull up and deform a ring of sheetmetal at each screwhole, which would interfere with sealing a new extrusion. Dimpled with tapered metal punch. Injected caulk to seal these screwholes in sheetmetal and foam.
Installation:
Nucamp mounted the original extrusion off-center by over 1/2", compromising function of clasps. I'd played around and re-drilled the hinge setscrew and I think ground part of the extrusion to shift it over into alignment. Quite a while ago. Nucamp overdrove and stripped most of the extrusion mounting screws (par). It was basically held in by the original strip of caulk/tape which retained its flexibility and adhesion.
The new extrusion has zero side play. Reusing existing screw holes left it too far off center. Lesson #1 learned being hasty in 100F heat index and literally getting burned touching hot metal and black plastic.
What I did not expect is that the vertical distance between hinge point and latch centers is greater, requiring one to mount the extrusion about 5/8” higher up on the camper. Lesson #2 learned being hasty in 100F heat index.
Marked centerline on new extrusion and laid out centerline of opening with great care. CRITICAL STEP done at 7 pm when the overhead furnace shut down.
Used blue painters tape for temporary marking.
Predrilled (undersize) two endholes through extrusion to TAB and fastened.
Window installs by holding vertically, overextended from normal opening position, inserting bent top into extrusion, and gently rotating window downwards whilst keeping top of window pushed vertically up into extrusion slot. It took several tries each time I did this which was iterative as I tested, adjusted, and eventually re-did the installation alignment. Stood on my front boxes and was close to over-balancing backwards in order to clear the swinging window in front of me.
Once alignment was (finally for third time) confirmed for latching, drilled balance of mounting holes, taped off perimeter of Tab around extrusion, caulked evenly spread layer (1/8” or so) of caulk on backside, and installed with provided self-tappers which I hand-set to avoid overdriving.
Ran another bead of caulk topside, finger smoothed, and removed tape. Cleaned up any gummies with Naptha and rag.
Inside, I hand-screwed the two screws to each side-support and closed and latched window.
A stack of foam scraps spaced the window away from opening so as to create space to install the pivot-mount screws.
Then carefully aligned and hand-screwed the bottom latch receivers atop pair of support spacers.
Tested physical operation, then water spray-tested for leakage. 70 mph winds may still drive some water past seals if not tight, TBD.
Two salt tablets, a very cold shower, and some hours later I feel better having replaced this window on one of the hottest days I can remember.
Excellent write-up and photo support. I know a fellow T@Ber who is thinking about doing this project.2016 Outback 320
After 9 seasons, we realized the extra play in our 2017 320 CSS was the broken plastic hinge. We ordered the replacement window from Missouri Teardrop Trailers and received and installed the new window and required flathead screws. Extra latch brackets were included, but not needed as the originals and location lined up with the new window . Part number 24426 PRICE: $308.99 + tax and shipping. It arrived in 1-2 days. Our gasket (seal) and gasket filler were intact and did not require replacement, so, be sure to check that before you place your order as they were initially going to send us the whole package.
Thanks to Maxcamp above and rh5555 in this discussion linked here
https://tab-rv.vanillacommunity.com/discussion/comment/195394#Comment_195394
we were able to replace the old window with the plastic hinge, with the new, metal hinged window.The black plastic stop on the passenger side of the old window was removed by tapping with a screwdriver and hammer. The window was then slid over to the drivers side and removed. Then the old hinge was unscrewed and removed and the adhesive cleaned up with 3M Adhesive remover using a rag. (DH said it was like magic!). Old screw holes sealed with clear, all purpose sealant.
Next, we secured the support arms with tape, placed the hinge on the new window, then secured the window in place using the inside latches, bottom, then the sides in the vent position keeping the window centered. (Not sure why we needed to use the “vent” position of the latch, but it worked.)
With the window temporarily in place, we applied masking tape to the trailer with the bottom edge aligned with the top of the hinge and marked the ends of the hinge on the tape.
Removing the window after tape applied to trailer. Then removed the hinge from the window.
Tape and the old holes sealed with clear sealant.
Hinge mounted with top edge 1mm higher than the bottom edge of the tape. No pilot holes required. Self tapping screws worked easily.
Trial run before we removed the adhesive backing on the hinge. (Smart move rh5555!)
Here are the old and new mounting holes. The old holes on the bottom become covered by the new hinge.
Hinge in place. Replacing the window requires a severe tilt above the opening. Then it was easy to reattach to the inside support arms.
Lastly, we caulked the top edge of the hinge with GeoCell.
Don’t be afraid to do this yourself. We typically don’t do DIY, but, other than fretting about making more holes in the trailer, it was a relatively easy job. I am really surprised that there is so little info out there about this procedure ( no YouTube😂).Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio2 -
Thank you all! I just ordered a new 400 window this morning and these write-ups will be quite helpful.Rich2019 T@b 400
I feel like I am going to puke. We are not DIY people at all which means we will be paying labor to fix this. We don’t own tools except very basic. I am so angry with NuCamp right now. The window fell out, the cabinet doors are falling apart, the shelf above the passenger side window fell down. Things were going so great for so long.
We've slept in 36 states, 2 countries & counting0 -
Update that is not really an update. I’ve spoken to Dan at the distributor and the manufacturer will be producing a new old style window and expect it to arrive in March. You will be able to just slip it in to the old frame If it’s just that your clip is broken, which ours is. Stand by for news!
We've slept in 36 states, 2 countries & counting1 -
@ColleenD2 Any update on “new” old window? What is contact info for Dan at distributor. Who is manufacturer?2022 T@B 320S Boondock0
Hi All- I’m so appreciative for this string. The step by step instructions were great. My 2018 t@b 320s front window had the plastic piece in the hinge crack & fall apart which meant the window couldn’t be opened without falling completely out. I also didn’t feel confident in its waterproof-ness.
I ordered the new window from Nucamp & it arrived in two days.
I read, re-read & quadruple-read the detailed instructions (in here) before I summoned the courage to tackle the project. Most of the time is for the prep- removing the old caulking from the old hinge area & cleaning it well so the new hinge caulking would adhere as well as possible.
Just needed an extra set of hands for the measuring the hinge location & for the “dry run” (pre-caulking) placement.
I feel pretty good to have done this at home & to have saved a few bucks! Thank you to everyone who contributed their experience/knowledge for this project.
Now- any thoughts about what to do with the old window? Aside from the lack of a hinge, it’s in great shape!
I’d love to hear any thoughtful and/or creative suggestions!
NH - 2018 T@B 320S-Silver/Black Trim - TV 2014 Toyota Highlander-Blue/Gray0 -
We have had the front window fall out many times on our 2024 400, it finally cracked. As with the rear window, opening it just a little leverages it up by the stand offs and it comes out of the rail - poor design IMO.
Is this new replacement an improvement, that is, is the hinge reliable when the window is open to any amount?
I tried re-epoxy twice on the plastic front window hinge on my 2021 T@B 320-CSS, but keeps coming off after a month or two. So I ordered Part #2446 tinted 320 front window replacement from a NuCamp dealer. It drop shipped from NuCamp very quickly and arrived well-packed and boxed. Just two pieces, the window and the extrusion/hinge. I have a few questions for anybody who has purchased this:
* The mountable extrusion/hinge - I think I misunderstood the discussion above. Is there supposed to be some sort of peel off adhesive on it? There's not. What caulk or sealant do you recommend? I plan to dimple and seal the old screw holes with Geocel ProFlex RV sealant.
* I tore apart every piece of foam in the box. There are no screws! See packing list attached. Did you receive the self-tapping screws in the box? Were they hiding somewhere? I guess I need to contact the dealer.
* The bit above about mounting the hinge 1 MM higher than the bottom edge of the marked tape, is that from instructions anywhere or just best practice or experience?0
