320s non-Boondock ground clearance
Has anyone modified their non-Boondock 320 to increase ground clearance, such as installing lifting blocks/spacers? I see some kits available (e.g. through Dexter), there may be others, and curious on what others may have experienced. Thanks.
    MuttonChops Member Posts: 2,078
    IMHO, the only realistic approach is to replace the Axle with the Boondock 'pitched' axle.
    {this figure shows the axle pitch . . in the early years a Boondock was named 'Outback'}
    As the Torsion Axle mounting method does not allow 'added blocks', etc that is possible with a leaf spring axle.
  • Dsea01
    Dsea01 Member Posts: 3
    Thanks for the response. Did you modify yours, or is it the outback model?
    Back in '18 nüCamp still did special orders so I got a custom build
    pitched axle, front cargo shelf, and I requested the then NEW 3020 Alde with it's High Altitude Combustion Fan Mode. Doing custom I avoided the silly 'Boondock/Outback' standard rear brush guard stuff. It's Kind-of-a Boondock Lite set-up that was available for a few years after '19.
  • Dsea01
    Interesting, thanks for the info. I’ll look into the cost for a pitched axle in my region and see if it’s worth it.
  • Grumpy_G
    Grumpy_G Member Posts: 787
    At least the older axles had custom mounting flanges which didn't work with the usual lift blocks/spacers. Hence using a Boondocks axle was pretty much the only solution aside from completely redoing axle mounts etc.. This might have changed recently but I only know for certain that 2025 400s use off the shelf axles.
