320s non-Boondock ground clearance
Has anyone modified their non-Boondock 320 to increase ground clearance, such as installing lifting blocks/spacers? I see some kits available (e.g. through Dexter), there may be others, and curious on what others may have experienced. Thanks.
IMHO, the only realistic approach is to replace the Axle with the Boondock 'pitched' axle.
{this figure shows the axle pitch . . in the early years a Boondock was named 'Outback'}As the Torsion Axle mounting method does not allow 'added blocks', etc that is possible with a leaf spring axle.
Adventures: 50 Nights: 415 Towing Miles 50,6501 -
Thanks for the response. Did you modify yours, or is it the outback model?
Back in '18 nüCamp still did special orders so I got a custom build
pitched axle, front cargo shelf, and I requested the then NEW 3020 Alde with it's High Altitude Combustion Fan Mode. Doing custom I avoided the silly 'Boondock/Outback' standard rear brush guard stuff. It's Kind-of-a Boondock Lite set-up that was available for a few years after '19.'18 320 S, pitched axle, 3020HE; PNW based
Interesting, thanks for the info. I’ll look into the cost for a pitched axle in my region and see if it’s worth it.
At least the older axles had custom mounting flanges which didn't work with the usual lift blocks/spacers. Hence using a Boondocks axle was pretty much the only solution aside from completely redoing axle mounts etc.. This might have changed recently but I only know for certain that 2025 400s use off the shelf axles.
