New 2026 TAB360 CS power/battery monitoring?
New owner of the TAB360 CS with boondock battery upgrade.
I am trying to get used to all the controls etc. for power sources. I have the Victron app on my phone and am using that. It seems that this app is the only way I can monitor batter charge storage status. It would be nice if there was a control panel where I could see state of charge on the battery, without relying on my cell phone app.
Am I missing something? Thx
2026 TAB 360 CS with Boondock upgrade
Tow vehicle: Ford Ranger 2021
  • Gomers2
    Gomers2 Member Posts: 159
    You are not. The Alde system uses the battery, but it is a separate system and manufacturer. The Victron app does take some time to get used to, but contains a lot of useful info. It's common to have some uncertainty but as you get used to it, and as it becomes clear that the system works as intended, it becomes second nature and you will probably check it less often. (Some batteries do have Bluetooth capabilities, and they can be additionally monitored on an app from the manufacturer, but that would be on your phone as well.). Welcome to the T@b scene, enjoy!
  • Horigan
    Horigan Member Posts: 912
    Victron makes a version with an actual gauge. BMV 712 (w/ Bluetooth) and BMV 700 without Bluetooth.
    https://www.victronenergy.com/battery-monitors/bmv-712-smart
    Rich
    2019 T@b 400
    Bellingham WA
    pthomas745 Administrator, Moderator Posts: 4,672
    Which exact battery setup do you have? If you are looking for a display, the device that Horigan shows does have a small screen. The apps are an easy read.
    There are other "shunt" type devices from Renogy and other companies that have "better" displays compared to the Victrons.
  • albireo13
    albireo13 Member Posts: 4
    Thanks all.
    I was thinking about the case where I might want to rent the camper later. I'd need to train any renter on using the app, which would be a PITA. LOL
  • Horigan
    Thanks @pthomas745! I forgot about the Renogy, which we have on our boat. It has everything clearly displayed on one screen.
    Rich
    2019 T@b 400
    Bellingham WA
  • Marceline
    Marceline Member Posts: 1,773
    edited July 5
    Here's an external display that can be connected to the solar controller but it won't display SmartShunt data:
    https://www.victronenergy.com/display-and-panels/mppt-control#downloads-manuals
    Victron does sell control panels but it seems like overkill ($600+) for a T@B.
    https://www.victronenergy.com/communication-centres/ekrano-gx
    Maybe get an old mobile phone, wipe it, and use it as the dedicated device for the Victron Connect app?
    MuttonChops Member Posts: 2,062
    edited July 5
    Off Topic:
    " " other 'shunt' type devices from Renogy and other companies that have "better" displays compared to the Victron " "
    Another reason I enjoy my before everyone linked their stuff to a cellphone app set-up.
    One 10A trickle solar charger and another 150AHr Portable (homemade folding) solar panel.
    Connected to a basic PWM Lead-Acid/AGM Compatible Controller with a very simple [China] hardwired shunt . . . there is a simple display in the cabin that always displays it's calculated battery SOC, there are three buttons total to select functions.
    Even when I forget how everything functions, shunt or controller, a few random button presses
    wakes-up-the-old-mind ☺️
    edited July 5
    @albireo13 said:
    . . . was thinking about the case where I might want to rent the camper
    You are one brave person - - - - I have issues loaning to family!
    Case in point. Long ago I allowed my teenage Daughter to take my most beloved 4x4 SWB with a simple dog-house shell on a camping trip. The only RULE was, You and Only You Drive My Truck. I figured one rule was all I could hope for and after several years she still says, Yes only she drove.
    Of course I was a wreck the entire weekend. Over the following months I heard comments or parts of conversations along the lines of "Gosh, driving in 4x4 low** is Soooo fun. You can really go anywhere"
    Yep, my worrying was justified. 😂
    Seriously:
    When the Dutchman T@B first arrived a few Dealerships did rent them.
    One Dealership created a two-page TIPs document.
    Short enough to be read while containing the most important information.
    Consider writing one for your 360.
    DM TaB Tips PDF Attached for reference.
    ** I did show she how to correctly engage Low Range (if needed. I said)
    But I'm not a foul an knew 'adventures' were ahead.
    That truck was a Manual, which
    helped in controlling who would drive.
    In the early 1990's most teenagers never saw a clutch
  • AndreaPalumbo
    AndreaPalumbo Member Posts: 16
    I actually share in the OP's desire for a stand alone control panel.
    Ultimately I just settled on using my cell phone app and calling it "good enough", however I did briefly entertain the idea of just purchasing a cheap "burner smart phone", or even a very inexpensive small tablet dedicated for the Victron. One could fasten it to the wall with glue, command strips, or some other means. Of course you'd have to devise a way to route power to it to keep it charged.
    Again, after all of this mulling, I just decided it wasn't worth it and just settled on using my phone.
    But considering your rental plans, it might be worth considering…. just as long as your guests don't steal the phone! (as always, YMMV).
    2025 T@B 400 (original owner)
    2013 Silverado 1500 (T.V.)
    Stanwood Washington
  • AnOldUR
    AnOldUR Member Posts: 1,759
    Mounted an old iPhone on the wall next to the television. Great to have a backup for various apps including Victron. Still a useful tool even without service.
  • rydfree
    rydfree Member Posts: 43
    On my last camper I just mounted one of these. All I want is to see is the voltage and current state of charge at a glance. I have an extra that I plan to mount in the 320 Boondock, just haven't gotten around to it. I'm just going to mount it in the end panel of the passenger wheel well since that is where my two Battleborn batteries are located.
    Amazon.com: Smart Battery Monitor12V 24V 36V 48V 60V 72V, SUPNOVA 7-100V Digital Voltage Tester for Car & Golf Cart, Battery Capacity Percentage Meter with Buzzer Alarm and Temperature Monitoring : Automotive
