Needed: Relighter for 3163. PN 633326 or old PN 617964
I have looked everywhere I can think of and can not find anyone that has this relighter. Hoping someone will have one to sell. The most current part number is 633326. It has been discontinued without replacement. All the websites that "say" they have one in stock, actually do not.
Thanks for your time.
    MuttonChops Member Posts: 2,033
    Are you 100% sure the Relighter Module is bad?
    Poor placement of thermocouple tip in flame, dirty tip, or just bad thermocouple should be eliminated.
    Also, confirm the "interrupter" is good and has good electrical connections.
    Have you read/seen this Forum Post on Interrupter
    A google AI search:
    " how to Test the interrupter component of the thermocouple circuit on a norcold 3136 relighter wiring "
    Includes these remarks:
  • dscott
    dscott Member Posts: 10
    Yes, 100% bad
    You may be forced into 'creating' a solution; bypassing the Module and installing a manual piezo igniter.
    I suspect the 3136 Interrupter 'wires' are output signals for the Module logic and that the interrupter would still shut-off the gas if thermocouple voltage/current dropped out . . . but that needs to be verified to have a safe solution.
    The 3136 uses a light wave-guide from the flame to the front panel indicator so 'burner on' indication should still occur.
  • dscott
    Thermocouple is fine and confirmed. Interrupter is fine and confirmed. Relighter is bad and confirmed.
  • Grumpy_G
    Grumpy_G Member Posts: 761
    edited July 14
    There is a company "Dinosaur Electronics" that make a lot of aftermarket boards for Dometic and Norcold, however they don't have anything listed specifically for the 3136. They do have universal igniters that possibly could be adapted. Their website/documentation is absolutely horrible though.
    Edit reason: I suck at spelling.
  • Bassaholic
    Bassaholic Member Posts: 3
    I'm changing out my norcold 3163; it would ignite, but not cool. If you want the igniter module you can have it, just cover shipping. PM me if you're interested.
  • dscott
    sent a PM.
  • dscott
    Bassaholic: Received your "old" igniter last night and installed this am. A heartfelt thanks as working perfectly. I do not use the propane fridge often, but want it, when I want it.
    pthomas745 Administrator, Moderator Posts: 4,637
    @dscott @Bassaholic This is great! We need a Norcold junkyard "Pick-A Part!"
  • Bassaholic
    I still haven't disposed of it yet ☺️
