Push button latches not working
The push button latches on our 2022 Tab 400 are not working well, I.e. the drawers and cabinet covers they hold closed are coming open during travel. Two days ago we went into the trailer at a rest stop and were chagrined to see that an entire drawer had fallen to the floor and its contents spilled out. The buttons are not popping up on the latches - they just don’t stay locked. Any suggestions?
Thanks.
Greg Reese
Happened to me on my 2024 400. At least in my case, the solution was to add some washers under the receivers (or whatever they’re called) for the latches so the part that pops up has more to grab on. For is, a few shelves were only barely catching, and transit was enough to shake ‘em loose.
Here is what I've done to fix this issue.
2018 Honda Ridgeline FWD
2020 400 solo
Fulltime rving since 2006/ tab since 20211 -
Thanks guys. I’ll look into these fixes
Greg Reese
After closing the drawer or cabinet door, push the button in and try opening the drawer or door. If it opens, see if the metal bar is projecting out from the white plastic mechanism on the inside of the drawer or door. If the metal bar is not sticking out, try putting a drop of silicon or light oil on each side of the metal bar and into the mechanism. Then operate the button several times to see if the metal bar will project out smoothly.
If the drawer or door opens and the metal bar is sticking out, then the "L" shaped bracket attached to the cabinet above the metal bar may not be sticking out far enough for the metal bar tp catch on. Add a spacer (washers, cardboard, plastic, etc.) between the "L" shaped bracket and the cabinet to cause the bracket to stick out further.
As mentioned above, you may also need to add a spacer behind the white mechanism so the metal bar can stick up behind the bracket when you push the button in.
Depending on your climate, the wood drawers and doors can swell or shrink.. That can affect how the push button mechanism aligns with the metal bracket. The latch may seem to work when the trailer is not moving, but one good (bad) bump in the road could cause the latch and bracket to misalign for a split second and fail. (The curved wood doors in our 2022 400 warped so badly that I had to completely replace the doors.)
EDIT: (Geez, that was a long-winded way of saying if the mechanism is working properly then it's probably an alignment issue…)
2022 T@B 400 BD, 2018 Toyota Tundra, Palisade, CO1 -
the round knob can be turned to adjust the latch mechanism. Clockwise to tighten or counter clockwise if too tight.
400 - 2019
St Catharines, ON0 -
They are available on Amazon.
2018 320CS-S
"Just Enough"0 -
I just went to Amazon and typed, "push button latches for rv cabinets". most of what comes up are wider than tall. these would not work on the curved cabinet. As you scroll down, there are latches that grip the area around the hole. these may work.
2018 320CS-S
"Just Enough"1 -
I would search Seaworld nickel RV push button cabinet latch. Seaworld is the brand on our 2019 400. You'll find ones for the flat cabinets. I would contact NuCamp for the curved latch on the 400 as it has a dual latch mechanism, and doesn't have a vendor name on it, at least on our 2019 400
Rich2019 T@b 400
@bandr1tnj, Then if it were me, I would just buy a regular flat Seaworld latch and use that to hold the curved cabinet door closed.
Rich2019 T@b 400
2025 Toyota Highlander 2.4L TurboBellingham WA1
