Intermittent Charging
This is an update and clarification to a post that I made last year regarding my 2021 T@B 320S, with two, 100AH Lithium Batteries.
I have noticed this year that my batteries (again) stop charging, intermittently.
Intermittently, my battery level starts dropping (slowly, due to normal phantom draw), even when plugged into shore power. So, I assume the batteries are not being replenished by the charging system.
I removed and checked all of the fuses in the system. They were all fine.
After reinstalling the fuses in the battery compartment, the system started charging again! The charge reached 100% and held for a week or so.
Today, I see the charge level dropping again so I assume it is not charging, even though I haven't moved the camper or touched the wiring.
Does anyone know which wires or fuses might contribute to this condition? I assume it would be one of the 30A fuses (or wires) circled in red below. The last fuse I touched was the small (3A) inline fuse supplying power to my Victron shunt (yellow circle). This doesn't make sense to me, but my electrical knowledge is very limited.
I'm not sure, but the issue seems to have started about the same time that I installed new LiTime batteries. I'm guessing I may have a bad connection somewhere near the batteries…but I'm not sure which wire it might be.
Sorry for the long post, but any help would, again, be very much appreciated.
Could you post a picture of the victron smartshunt and the associated wiring? (I assume that is what you are using to judge the battery level).
Please describe your "charging system". Are you using the standard converter or the LiFePo capable model ? Is there any solar charging happening during the day ?
Generally speaking the standard WFCO converter puts out 14.4V in bulk mode which is enough to charge a LiFePo battery. However it drops to 13.6V (absorption) after 4 hours and even lower to 13.2V (float) after almost two days. 13.2V is lower than a fully charged LiFePo battery so at this point the battery will start to draw down a bit.
@Gomers2 . Yes, I am using the Victron Smart Shunt. It's in the upper right hand corner of the photo above, but I'll try to get a better view showing the wiring. The device to the left of it is just a negative buss bar.
@Grumpy_G . I am using the original, standard 'lead-acid' converter. I have the original, factory 105W, roof-mounted solar panel which is contributing to the charging….though it doesn't get a lot of sun this time of year. I also have a 200W suitcase solar panel with its own controller (seen in the photo above). However, I usually only connect that when I'm camping.
I did suspect that it was a function of the original converter. However, left un-checked, my batteries dropped very low (down to about 20%) because I assumed they were charging.
Thank you for your help!
@Grump-G. Thanks again for the help. Sorry…but I am really struggling to understand the charging system!
So, based on your comment above, are you saying that the original converter output reduces over time…regardless of battery SOC? I have left my system plugged into shore power since recharging the batteries to 100% (with an external, lithium charger). They have slowly dropped to 70% SOC (13.2) volts, from normal, phantom draws. Does this seem normal? If working properly, should it remain at 70% until I use additional charging methods (solar, external charger). I don't remember this happening last year, but maybe conditions were different.
Thanks once more.
13.2 V is the float mode of the WFCO converter. According to their documentation it goes into float mode after 44 hrs with no change in DC current. It is supposed to go back to 13.6 V absorption if the current increases. I've never tested it but turning on a couple of DC loads should accomplish this. In any case, 13.2 V is not enough to charge a LiFePo battery so I'd think it will experience a self discharge rate of 2-3%/month even though it is not supplying power to any external load (the load is covered by the converter).
One thing you could try is to disconnect shore power for a day or two every month which will force the converter into bulk mode upon reconnection. Or just hook up the external LiFePo charger once a month.
@Grumpy_G. Thank you! That makes a lot of sense. It's been holding at a steady 70% for the past week or so. I've only had the LiFePo batteries since last summer and, since I wasn't able to camp at all this year, I guess I never noticed this pattern. Thank you again.
I'd really like to upgrade to a new 'auto-detect' power center/converter that is designed to work with Lithium. It looks like the WFCO 8735-AD is a direct replacement. However, I've seen a lot of negative comments about reliability. Maybe next season!
I just installed a dedicated Li charger in parallel to the WFCO. Works great. I added bus bars to the battery cables to make it easier to add additional charging inputs, positive and negative. The Tabs only come with one stud.
Rich2019 T@b 400
Most, if not all of the reliability problems posted are the unreliability of the Auto Detect feature to actually detect a lithium battery installation. There is a model 8735LiS available that has a switch to select Li battery mode. It should be a direct swap for your existing WFCO-8735
https://www.wfcotech.com/shop/power-centers/wf-8735lis-power-center/
My 8735 AD (Li jumper) has been a stellar performer for 4 years…
