I store my T@B in the garage when not using it.  The battery is hooked up to a Die Hard Battery Charger/Maintainer on the 2A 12V setting.  After the battery is charged, a few days later the red light comes on and the panel in the T@B is blinking and beeping.  Not sure if there was a power fluctuation causing it, the battery, or the charger.  Has anyone else had this problem or thoughts?
Thanks,
                Allie
Condo A-Go-Go
2017 Tacoma (AH GOGO)
S. UTAH
0 ·
Condo A-Go-Go
S. UTAH
I have a DieHard, a really nice one that cost a bunch and came with great reviews, that after a few years of light use, began exhibiting those exact symptoms.
I'd say we each have a broken DieHard charger...
I hate to get rid of it, cuz sometimes it works, and it came with such great reviews. B-)
Condo A-Go-Go
S. UTAH
http://wfcoelectronics.com/product/wf-8740-40-amp/
Sterling, VA
Now if you don't pull the battery fuse it will drain a battery in under a week. depending on your model and what you have running it could be half that.
Cyclonic: yes, i could plug it into shore power. Just thought it would be easier using battery tender because it is very tight to get to that side of the trailer in the garage to use the plug.
Condo A-Go-Go
S. UTAH
If it's too hard to get to the electrical plug, you can get a simple Battery Tender (or there are other name brands). It looks like a transformer that plugs into the wall with a cord coming off of it. Be sure to get an extension to it (or use an extension cord) because you will need to plug it into the battery. It comes with a short cord with connectors that you attach to the battery. An accessory (or maybe it comes with it) would be alligator clips that clip to the battery. This will keep the battery trickle charged, whether you disconnect the battery fuse or not.
2011 Subaru Outback
Rockford, Illinois
I'm sure you don't leave your head lights on all of the time on your car/truck, which would require a jumpstart to be able to drive. This is basically what you're doing to your T@B battery. You're draining it with the parasitic battery draws of the Jenson, the TV, the CO detector, the fridge (if you forget to turn it off), etc
here is the chart that shows the minimum voltage you should allow the battery to go. Note that 50% is not 6 volts. .
2011 Subaru Outback
Rockford, Illinois
sorty to say, the technician at the dealer is completely and absolutely WRONG.
your battery is destroyed if you let it go completely dead, or below about 11.5 volts for 24-36 hours.
i think they ( the dealer) wants to sell you lots of batteries.
walter
OR, take the battery out and put it where the dogs don't do their doodoo on it :-)
2011 Subaru Outback
Rockford, Illinois
Condo A-Go-Go
S. UTAH
And you are correct, if the battery charge drops the tender will maintain and float the charge accordingly to ensure the health and maintenance of your battery when not in use. I installed a battery shutoff switch on my battery to eliminate the issue of parasitic drain on the battery from things like LED light circuits, the TV/stereo, etc. I'm very happy with it and do use it when it's in storage.
Minnesota
2016 T@B M@X CS-S pulled with a 2015 Ford F150 Lariat
Condo A-Go-Go
S. UTAH
1. Battery Shutoff Switch - I would consider mounting a shutoff switch to eliminate the parasitic drain and to help isolate your battery.
2. Battery Charge - I normally charge up all of my equipment batteries around the house (e.g., lawn tractor, boat battery, etc.) in late fall after I am done using them. I do not remove these batteries and since they are fully charged this tends to help them through the harsh winters here in Michigan. I have been doing this for a long time and have never experienced any adverse effects, other than the normal battery replacement that is a result of extended use via age and deterioration.
3. Battery Tender - If you have a power source in the storage area you can use a battery tender to maintain the battery. If not, go with the above tips or as you noted, remove the battery and hook a tender up to it at your home.
If you "do not" install a battery shutoff switch the trailer battery is eventually going to be drained via the parasitic drain, even after being fully charged for the season if you are unable to isolate it from the trailer's circuitry.
Another thing you could do is unhook the battery, take it in to a local AutoZone parts store and have them test and check the battery health for you. They can easily ferret out the problem and tell you whether or not you have a defective cell in the battery and get to the heart of the problem.
And as noted in the prior comments above, you could either remove the battery fuse or install a battery shutoff switch to eliminate any parasitic drain as your T@B unit's electrical circuitry and mounted components are definitely drawing power from the battery while idle and adding to the problem.
The T@B is definitely a horse of a different color and unlike your former Scamp trailer in terms of power drain, so factor in the above and go from there.
Would I keep the battery in good order if I plugged into shore power for a day every week or so? Or more often, or less often? Seems like an easy solution.
2014 T@B CS Maxx
Martha Lake, WA
Condo A-Go-Go
S. UTAH
