Portable Surge Protector Question
Vagabonds
Member Posts: 35
I have read through many posts on surge protectors and cannot find whether this has been answered or not....
Can you use the dogbone adapters with a portable surge protector/circuit analyzer? In other words, must I buy a surge protector for each potential voltage, or can I use the 30amp portable surge protector---post > dogbone (for example, 15 amp to 30 amp) > then 30 amp portable surge protector > 30 amp cord to T@b?
Many thanks in advance! Our CS-S Sofitel is waiting at the dealer for us until 2 October! Sooo excited!
Pam (and the husband..+2 golden retrievers)--2016 T@b M@x CS-S Sofitel (towed by a 2015 Jeep WrglrUnlim Rubicon)
Yes
Gil Butler, Folsom, CA, 2015 T@B M@XX CS - White with Yellow tim -
Thanks Gil!
Pam (and the husband..+2 golden retrievers)--2016 T@b M@x CS-S Sofitel (towed by a 2015 Jeep WrglrUnlim Rubicon) -
The surge protector is not a fuse, but must be rated to the highest potential draw, and for the T@B, that is 30 amps. You may use connected to 15 or 20 amp circuits. You could also use it on a 50 amp service with the correct adapter, but as the T@B has a 30 amp main breaker, that will limit the maximum current draw to 30 amps.Martin - Trailer name: James T@Berius Kirk
I use the 30 amp "dogbone"'at the pedestal. 'Does what it is supposed to, no mods or extra brain power required. Works for me.Sally, "PlaT@Bus" 2016 T@B Sofitel Maxx-S (plata=silver; SP), previously Little Guy 2014 Silver Shadow LE, TV -- 2013 Chevy Avalanche + two hounds.
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
