Ok. No hot water again. However, I discovered that I had a "little" visitor while my unit was parked in storage. He/She decided to chew the wiring that goes to the Alde Control Panel down thru the cabinet. I now will be getting with my dealer to have this repaired. Nothing like having hot water.
I would think using a surge protector would be easier and safer.Bert said:I want to make sure that I read Michigan_Mike's post correctly. After I arrive at the campground (or my driveway), I'm supposed to go into the trailer, throw (open) all the breakers, plug the trailer in, then close the breakers so the trailer has electricity. I have been noticing blue sparks when the Tab is plugged into or disconnected from power and had thought that it might be enough to blow a fuse.
If you are plugging at home, you should not set the Alde control, all the way to the top as your home wiring (unless you installed a 30amp outlet) isn't meant for that kind of draw. That could be the issue.Bert said:Thanks. I bought a fancy external surge and low voltage protector. I hadn't realized what it could do for me when I was plugging in at home
Jeanne said:I just found this post again after looking for it for sometime. We have had trouble with our fuses blowing in the Alde. I have obtained some with 250 amp, and hoping that solves the problem. (Actually it is the same fuse that blows every time.)Our T@B is also 2014, so wondering if we have the same wiring issue. Where was the facility in Washington that you used? Just finished winterizing for our first time, so I won't have any resolution on this until Spring. Hate putting the baby in hybernation for the winter. (Fortunately we live in WA)
A tester tests the line at that moment. It isn't a surge protector. A surge protector provides constant protection from low and high voltage spikes as well as other issues that can develop. This device might trip a circuit but it won't shut off the power flow. If it is damaged from a spike, and the breaker is reset, you have no further protection.PXLated said:I have just the small tester that also works as a surge protector - Somewhat similar to Chans. I think Verna has the same one I have.
PXLated said:Well aware of that. Don't think I ever implied it did.
I hear more about bad campground wiring than I do surges etc. so works out well for that.
Not so fast....PXLated said:VINDICATED - Thank you mash2 :-)
