BAL Leveler Wore Out
I just ordered a replacement threaded rod and trunion nut for our BAL leveler ($40)...which has badly worn threads (esp. the nut) from only 6 uses.  From what I've read...1) this is not super hard steel, 2) you need to grease the rod & nut regularly, and 3) you need to clean the rod & nut after every use, especially in sandy/dirty campsites.  Since we live in sandy/dirty country (hey, we were under several oceans in the last few million years), we'll be camping in similar conditions in the future...so I was wondering if anyone has found some tricks to keep this thing clean (I've read about using those foam pool "noodles").
J.D. & Sue
  • jkjenn
    jkjenn Member Posts: 6,425
    Wow, good to know. Who would have thought they would wear out so easily! I probably used it close to 6 times when out west. I will take a look at mine.
  • DurangoTaB
    DurangoTaB Member Posts: 754
    I'm thinking of bringing an old toothbrush along to clean out dust/sand from that trunnion nut.  I like the idea of a simple sleeve around the threaded rod...either the "noodle" foam or a piece of PVC.
    J.D. & Sue
  • Cyclonic
    Cyclonic Member Posts: 1,232
    Very good to know, I have had no issues with mine after many uses, but I don't deal with dry, sandy camping too much.
    Sterling, VA
  • IACamper
    IACamper Member Posts: 109
    I use Fluid Film on my stabilizers. The first time you spray it on, it foams off all the dirt and gunk. It leaves a relatively dry film that Stays clean, which is what makes it so good for the stabilizer screws. I may try it on my BAL, also.
    Kristi Des Moines, IA 2008 T@B L
  • Michigan_Mike
    edited February 2015
    This is the company that produces the Bal-Leveler.   I did find an old thread (2010) where a member contacted them and was able to purchase replacement parts cheap.
    BAL RV Products Group
  • DurangoTaB
    Norco (Elkhart, Indiana...where else!) makes the BAL leveler...you have to get the part number from them, then order through a distributor, e.g. Colaw... http://www.norcoind.com/bal/products/consumer/leveling_products/dealers_tireleveler.shtml
    ...who then contacts Norco to ship it to you.  I've ordered both replacement parts.
    J.D. & Sue
  • Michigan_Mike
    The circle of parts!  LOL
  • Bill_in_Tulsa
    Bill_in_Tulsa Member Posts: 65
    What are the part numbers please?
    TIA
    Lynn and Bill-in-Tulsa
    2016 Silver Shadow 5x10 ~ TV 2016 Ford Transit 350 Wagon XLT van.
    "Find the Magic in a Teardrop Trailer"
    Tulsa, Oklahoma USA
  • DurangoTaB
    Sorry...it's been so long I don't have the info.  I'd call Colaw...8775482125
    J.D. & Sue
  • Bill_in_Tulsa
    Thanks
    Tulsa, Oklahoma USA
  • Mouseketab
    Mouseketab Member Posts: 1,262
    Wow, I've been using mine for 5 years plus, and don't grease it or clean it, except maybe to hose it off a little bit. Never had any trouble.
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
  • Bill_in_Tulsa
    I however after receiving mine a week ago have decided to use spray on graphite and wipe it down after every use. If you use grease on a lead screw and do not clean it every time, sand and dirt will build up and act like sand paper... just my thoughts on this device...
    Tulsa, Oklahoma USA
  • jkjenn
    Mine gets much dirtier when I camp out west. There is almost always sand particles in the air that get into the grease.
  • Nomad
    Nomad Member Posts: 7,209
    Don't have to grease or wipe down my Lego blocks :-)
  • jkjenn
    @PXLated, I tried your Lego blocks on my last trip and I didn't care for them. You cannot dial into be exact. I was either too high or too low at my Ridgway campsite. I pulled out the BAL and was able to quickly dial it in to be exact.
  • Nomad
    edited October 2015
    You're taking my dig too seriously Jenn...Was just razzin ya'll with the fancy cranky things...
    But no problem here - Got one that's a half block. Perfect every time...
    Well not if I've got to get an 1/8 of an inch but close enough for government work :-)
  • alanmcd
    alanmcd Member Posts: 13
    Mine wore out a couple of years ago after about 5 or 6 years of use. I just use the yellow leveling blocks. Just as easy. Probably easier because you don't have to get as physical as cranking that lead screw with a ratchet.
    -Alan
    Cincinnati, OH
  • DurangoTaB
    Alan...I use a cordless drill and a 3/4" bit to crank the BAL leveler up & down...MUCH easier than the ratchet!
    J.D. & Sue
  • Nomad
    You know what we think you guys/gals and your drills - wimps!
    If I ever get one I'm sure not going to admit it ;-)
  • alanmcd
    I use a V8 engine in my F150 to pull the T@B onto blocks. MUCH easier than a cordless drill.  ;-)
  • mash2
    mash2 Member Posts: 584
    Its a blender not a drill.
  • Nomad
    mash2 - Oh, that's right, you disguised yours.
  • I couldn't even imagine trying to get the trailer on any sort of blocks! I love the BAL leveler. It takes no effort at all. I put it around the tire, a few easy cranks with the ratchet and I'm set.  I'm a female too who is not in shape, and its nothing to crank the nut to level the trailer. I wouldn't trade it for anything.
  • Nomad
    Robyn - Wait until you have to raise both T@B tires because of the downward slope of the site - Couldn't get the tongue low enough for level without raising the T@B.
