Winterizing?
What do I need to do to winterize our trailer?  We only have a sink with cold water.  Thanks
bill
2015 T@B  Yellow Q-Plan
  • Verna
    Verna Member Posts: 6,876
    bill
    Bill, if you do a search for winterizing, there are many topics on the subject. Because your Q model isn't mentioned a lot, you'll probably have to take the info you find and adjust to your piping.  Common winterizing would be to drain all of the water you can from your tank, blow the water from your lines, be sure to put the pink RV anti-freeze in your traps.  I'm sure others will have more to add.
  • Sidhalemm
    Sidhalemm Member Posts: 13
    Thanks for the tips.  So I don't add the antifreeze to the water reservoir?  I must unhook a hose from the water pump and pump the antifreeze that way?  Thanks
    bill
  • Sidhalemm
    Hi Sandra.  Ya, we have a little guy T@B   I put some in the tank and pumped it into the sink.  What do I do about the water line where you attach the hose?  Do I just blow air into it to flush it out?  Thanks
    Bill
  • Sidhalemm
    Oh, what about the tires?  It's ok that the trailer just sits on the tires all winter?  I don't need to jack it up on blocks?  Thanks again
    bill
