Please please check to see if the pump is getting hot (I doubt it since it sounds like you were checking it a lot)! Sister's Outback pump went out after 1 camping use. Blew 2 fuses on 2nd camping trip. Put in a slightly heavier duty fuse. BTW, voltmeter verified power. That pump got too hot to touch in a matter of minutes and the switch wasn't even in the on position. Pulled fuse, warranty item (whole bad story in itself, but not related to LG - just the dealer).DABWCA said:Checked in at Blue Mounds State Park this evening with a full water tank, but discovered that nothing happened when I turned the WP on. Serious problem for some hungry travelers. I'm plugged in and all other appliances seem to work. Now I have no running water, hot our cold. The pump worked on my last trip. Any helpful advice would be greatly appreciated. All of the circuit breakers are switched to the on position.
