good tools for Alde maintenance
ChanWChanW Member Posts: 3,163
Our Alde has been in service for a couple of years now, so I checked the fluid to see how it's holding up.
I found two handy & inexpensive devices on Amazon that worked pretty well:
Etekcity PH tester and the Grand Index coolant refractometer
Coolant will get more acidic over time, so it's a good idea to keep an eye on it, and the glycol loses it's effectiveness over time.
The PH level of the coolant can be checked with a digital PH tester or PH test strips. PH should measure between 9.5 & 10.5. If it's too acidic (below 9.5) it can corrode the metal parts in the Alde.
The glycol concentration level (percent alcohol in the fluid) is best checked with a refractometer (a hydrometer doesn't work correctly with propylene-glycol). The glycol freeze temperature should be kept appropriate for the temps that your Tab expects to find itself in.
Just FYI, after 2.5 years, my Alde fluid PH is 10, and the glycol has a -8F freeze point. I'm going to see about boosting that glycol a bit.
  • jkjennjkjenn Member Posts: 6,413
    Meanwhile, imam still looking for a local source for the glycol. That might be my weekend challenge.
    It seems that this would work,  It has Propylene Glycol. http://www.camco.net/Products/Item?prodID=10591#.Vj1pJ4-cHic
    I am not having any luck locally finding the Sierra brand.
    Peak I believe bought Sierra. Check peaks website. I got mine at O'Reilly auto parts.
    The dealers they say that carry it don't, in my area.
    Are they able to order it, Jenn?  The Sierra Peak their website refers to is the pink antifreeze for our water pipes.
    I will check. The only 2 dealers are Dollar General (doubt they would order it) and Advanced Auto.
    Prestone Low Tox is another you could use. $26 on Amazon.
    edited November 2015
    I found Prestone Low Tox at O'Reilly's in Indianapolis.
    Dollar General and Advanced Auto only had the Sierra Peak pink antifreeze for water lines.  I took a Photo of the Sierra Peak to O'Reilly's and they had never seen it. I did not check Camping World....and I just searched them and Camping World only carries the pink water line antifreeze.
    I think one of the most important specs with the 'Coolant' type of Propylene Glycol is that it have "corrosion inhibitors", ie: esp. for aluminum engines, is what I've read.
    I made the mistake of trusting the salesman at West Marine (he was in a hurry to close for the day, so I didn't take the time to read the bottle), and I found I'd purchased the plumbing antifreeze glycol that they carried.
    I've now bought a jug of Prestone Low Tox, and am waiting for a response from them re: how well it will mix with the Sierra that is supposedly in mine. I'm also waiting for a response from Ed Kauffman about how much the system holds, ie: for draining and replacing it.
    Yes boo, that's my thinking on it.
    The manufacturer of the Alde has a recommended change time on the coolant, but I'd wondered how long it would actually last. These give a little more information to go by.
    The one bit of info I didn't get was what the percentage/freeze-protection was that LG initially installed when they put in the Alde. ie: if the freeze-protection is only -8F now, what was it when they installed it? I'd think in western NY state, and many other northern states, that -20F would be more appropriate.
    A little more info....
    "Freeze temperature" is different from "burst temperature" when talking about antifreeze.
    From what I've read, "freeze temperature" is when the fluid begins to crystallize into a slush, and "burst temperature", or frozen solid, is usually 30 degrees F colder (or more). I'm pretty sure though, that you wouldn't want to turn on your Alde even if the fluid was only a slush. It might be a bit hard on the Alde's circulating pump!
    And -50F protection might be smart in many places, with that global warming 'more intense winters' thing and all...
    Here's the scoop
    Ed Kauffman sez the Alde system holds 1 1/2 to 2 gallons of coolant.
    Prestone sez that their "Low Tox" antifreeze should mix ok with Peak Sierra's propylene glycol antifreeze. Quote: "
    We haven't tested those two products for compatibility, however they are extremely similar and we would be very susrprised if there was any problem whatsoever with mixing the two of them together."
    Now I just have to do the math to figure how much to drain, in order to add the new Prestone, to get -50F protection...
    I'm sure I can remember my algebra... I think I can... I think I can...
    On another note, I read in my new Subaru's manual today, that they see no need to change the coolant before 11 years!
  • SgtjohnSgtjohn Member Posts: 238
    I bought mine on Amazon, I think it was $14.00 for a gallon if I'm not mistaken.
    Found mine as I was passing thru Sioux Falls - Only store that had it was one of the O'Reilly stores and they only had two jugs.
    Do you have a link? I couldn't find any that cheap.
    $99.98 for 6 one gallon jugs on Amazon of Sierra Peak Glycol is all I could find on Amazon.
    Ditto.
    Six of us should go in together and buy the 6-pack.
    and then meet in Kansas to split it up!?!
    Well, who is going to be in AZ this winter who needs it?
    You'd need antifreeze in Arizona? :o
    ChanW said:
    Cheaper at O'Reilly's. $18.18 including tax
    I hate snow--I winter in AZ.
    What's o'Reilly's?
    The map of store locations looks like New York state has banished them.
    Closest one to me is in PA.
    It's an auto parts store. The ones in Indianapolis don't carry the Sierra Peak Glycol-- you have to ask for the glycol, otherwise the search thinks you're asking for the Peak Sierra pink stuff for the plumbing ( and it's expensive!).
    When I told O'Reilly's it was a glycol anti corrosive anti-freeze for my camper, they immediately went to a new box of Prestone Low Tox that wasn't even on display yet.
