http://youtu.be/ULAJAGy3i2M
I was told to put the springs at a 45* angle and they would work fine. Too many things in the Verna-do list and I haven't gotten "round-to-it" yet.Sgtjohn said:I've already bought the struts and I'm running into some problems but....the springs are far more reasonable than the struts so guess what I'm going to do? I'll be making a trip to HD tomorrow to pick up those springs. The struts are hard on the hinges of the cabinet doors! Thanks!
Crystal, if your hole is large enough to hold a wooden toothpick, put some white glue or super glue on the toothpick and push it into the hole. Wait a while for the glue to dry and break or saw the toothpick to the correct length. Then drill a smaller hole than needed in the toothpick and screw the screw eye in. It works.TABaker said:My eye hooks won't stay in place any longer. Maybe I need to go up a size.
Sgtjohn said:I dunno why I don't have to bend the springs before I close the cabinet door, I thought I would have to but didn't happen. I think maybe it's the distance from he hinge etc.?
OutbackAZ said:I tried the springs without success. Went to these at Amazon ($9.35 a pair). RV Designer H279 Cabinet Door Support Plastic 6.25". Be very careful to insure the strut has enough travel to compress when the door begins to close! If not, it will pop the hinge off that side of the door which could possibly damage the wood ceiling above it. Once installed, they are a great mod.
I bought the springs also and for the life of me couldn't mount them properly so I went to the springs and had success for less. I cut a common screen door spring down and used it x2 on each door and it works great. I asked Amazon for a refund and they gave me a refund and let me keep the supports!!! I'd like to send them to someone and would if they'd pay the postage...send me a msg and I'll respond.
Here is a photo of the RV Designer H279.
That's what I thought. Not too bad.ChanW said:From the pic it looks like it would stay pretty much up next to the door when closed. Maybe stick into the cupboard a half-inch or so.
