Apple had a couple of updates to the iPhone two or three weeks ago. Ever since then, I have to log in to the T@B and LG forums each and every time I go to them, even if I'm gone for a second. Yes, I have the box checked to stay logged on.  Yes, I have "rebooted" many times on a daily basis. Yes, I have closed the apps and links many times.
This is not happening to any other forum or app, and I have a lot of them.  It is also not happening to my iPad, nor my MacBook Air. Only the iPhone.
Is this happening to anyone else?
Thanks
0 ·
PS. I have a MacBook Air and an iPad mini too and they don't seem to have problems. I don't think Vanilla likes iOS in general
Up on the right edge of the URL bar is the refresh circular arrow.
Press and and hold on that circular arrow and you should get a drop down menu...
Chose "Request Desktop Site" and see if that corrects the problem.
That is an understatement!
(And I'm still on the iPhone 5S because I had to buy it the day before the 6 was introduced. I was dumped off my kayak and the alleged waterproof neck bag was not waterproof. And, since I wasn't due for an upgrade yet, I had to pay full price.)
Try this - Go into Settings > Safari > Scroll down to "Passwords" ... In that list should be one for the forums ... Edit - Delete it ... Revisit the forums and login. A new entry should appear under passwords. Maybe that will reset it.
If not, do that same thing then click on that entry in passwords, it will show you your username/password ... Delete and re-enter.
Depending on which browser, the option is found various ways.
Which browser are you using Verna?
Under Settings/Safari/Advanced/Website Data then hit edit in the upper right corner.
Click the red minus sign next to vanillaforums.com.
That will remove all vanilla stuff, so you'll have to log in again, etc.
"I would advise those users to check their cookie settings and make sure that they are set to "always". I would also confirm they aren't in private browsing mode. Generally getting logged out would be some sort of cookie issue, unless there is some other error they are seeing. Let me know if something else seems to be occurring."
By the way, it seems to be working fine for me on the iPhone. It's kept me logged in through refreshes when I've tested it. I rarely use the phone for web stuff - screen too small - default to iPad. so I may not have tested it enough.
I've stayed logged in (knock on wood) for about 3 hours right now, on both forums.
I'm just used to the iPhone, small screen and all. I bought the iPad and MacBook because the Dell took so much data just to boot up. I do have a hotspot so I can use iPad instead of the iPhone, but I get throttled if I go over 5 gbs on the iPhone.
ChanW said:
