My water pump sounds like a machine gun! The pvc pipes in the shower wall bang like they are trapped drummers. I saw a picture of a similar pump here that shows flexible hose going in and out. Mine (2014 T@B S) has the same flexible hose at the inlet but has solid pvc on the outlet side and coming out under that small lavatory. I wonder why it's not all flexible water line. That kind of rattling in time would certainly create a leak I'd think.  Could there be trapped air in it somehow?
                "Not all those who wander are lost"- J. R. R. Tolkien
2014 T@B-S
0 ·
Mine makes a racket for awhile every time I run my freshwater low and refill it.
2014 T@B-S
J.D. & Sue
2014 T@B-S
J.D. & Sue
2014 T@B-S
Also, the smoke alarm is seems to be extremely sensitive. Maybe that's a good thing? I found a plastic bowl cover with an elastic band that fits over it perfectly. I cover it up when cooking, etc., and try my best to remember to take it back off.
Happy Trails Y'all
2014 T@B-S
So, you're saying there is a filter inside the pump itself besides the in-line one right beside it? I took that one off and discovered some small PVC shavings that I assume were from plumbing installation, but not dirty otherwise.
Happy Trails Y'all
Happy Trails Y'all
