Do we have to put Antifreeze while using the T@B in winter time?
Does anybody done this before? Comment please, it's getting colder here in my area.
2016 T@B Maxx S, Nissan Pathfinder
  • JltabJltab Member Posts: 89
    also anybody remember the ratio of dilution? (Antifreeze to Water)
    There are many discussions about winterizing. The search box is in the upper right corner of this page, type in winterizing and be prepared to read.
    Yep, search first - Almost anything has been covered at some point or another. New things do still pop up though.
    Short answer: Yes.
    Slightly longer answer: If your T@B will be exposed to freezing temperatures, you should winterize the lines by either thoroughly draining and blowing out all the water, or replacing the water with antifreeze.
    The aforementioned search will reveal the details and debates regarding how to winterize. Good luck!
