Hi all - Wanderoo is in Tucson (pre-move) and she hooked her T@B battery to a solar trickle charger T@B is in a storage facility). She is leaving today so hoped someone could answer this ASAP. She does not have a battery cut-off switch. Will the parasitic draw be more than the 7watt charger and if she pulls the fuse to the battery, will the trickle charger still charge the battery? She's afraid the trickle charger won't keep up with the demand from the parastic draw. My 6watt solar trickle does a good job of keeping the battery charged but I have a cut-off switch. Hope that's a clear question. She hoped to not have to pull the battery. OR should she pull any fuses inside T@B that would do the trick? Thanks!
![](https://us.v-cdn.net/5021717/uploads/editor/3h/qv1qsrc27fp9.jpg)
0 ·
And the photo is deceiving. Cindy Lou is actually as tall as my truck. I lost most of my pictures on the iPhone when I returned. I need to back it up soon and back it up frequently while on the road.
But thanks for the info. I'll store it for later use. Is this how you would copy photos from a flash drive, too? I have a lot of photos from the Dell on a flash drive that I want to copy to the MacBook.
Once you get the Mac cleaned up and back working, I recommend getting an external hard drive (they're pretty cheap now days) and a program called SuperDuper - It's free in it's basic form. It allows you to "clone" your internal hard drive - makes an exact duplicate. Once you have that, if something gets hosed you can start up from that clone and restore your internal drive back to normal.
