Red LED flashes if the
voltage to the boiler goes
below10,5 V (automatic
resetting at higher voltage).
Fixed light, the LPG boiler has
become blocked (resetting by
the central switch for LPG) or
overheated (resetting by the
main switch of the vehicle).
From the manual.
I agree with Verna... Normally bright/dim lights would indicate a bad ground wire and problem therein. Have you verified that the battery fuse on your tow vehicle for the dedicated feed to the rear of your vehicle is good? That's where I would start and I would work my way to the rear of the vehicle, check connections in the receiver and trailer wiring harness, verify at these points with a good LED volt meter that you have proper voltage and follow the circuit back into your trailer..... Water does strange things and will corrode connections during travel and in one instance I had a friend who had bad connections via corrosion and we also found a fuse that had been installed beneath the vehicle as opposed to having it fused at the vehicle battery. When others do this type of work you never know what they will do.Sgtjohn said:It is interesting that even with the TV connected there is no lights or power to the interior. Addendum, I just went out and checked the unit and the lights worked inside but they weren't as bright as the were on ac power. I think the battery may be the problem-the Alde light still blinks.
If everything is good on the TV than it is likely the T@b. If you check the 7pin in the TV and find a problem, you can rule out the T@b.PXLated said:If it's a bad ground on "the T@B" as you mention, what are you suggesting by testing at the TV - If everything is good to there, it has to be in the T@B?
Sgtjohn, seriously, if you wait until late next week, I can help. While not an electrician, I was a Central Office tech working with 52 Volts at the phone company.Sgtjohn said:Ha! I first read the "check out the TV fuse line," I thought the TV works on antenna and cable then I realized it referred to the tow vehicle. Now back to earth- I have power to the 1 O'clock position on the electrical hookup (looking at the rear of the TV). All the fuses within the converter are good and I checked the main ground with a probe to each 12v fuse receptacle after I pulled the fuses I and I had light/power using the main ground.
jkjenn, what would Camping World charge for an hour of tech labor? I imagine it would be around $125.00 and I'll call them to confirm. But, before I take it to them I'll try and isolate the problem and repair it myself.
@Sgtjohn- I hate to tell you this, but they worked on my T@b for 2 hrs..... for free. I will forever be a fan of CW as a result, especially, CW in Golden, CO. But, you should be covered under warranty still, right?Sgtjohn said:Ha! I first read the "check out the TV fuse line," I thought the TV works on antenna and cable then I realized it referred to the tow vehicle. Now back to earth- I have power to the 1 O'clock position on the electrical hookup (looking at the rear of the TV). All the fuses within the converter are good and I checked the main ground with a probe to each 12v fuse receptacle after I pulled the fuses I and I had light/power using the main ground.
There's always @Vernaand phone company employees know their stuff!Sgtjohn said:The warranty expired 10 Oct 2015. I had the T@B in my garage all year because of a shoulder replacement.
