![](https://us.v-cdn.net/5021717/uploads/editor/te/kswd5prx3j92.jpeg)
My new Tab has the SeeLevel monitor in the kitchen area. There is a light above the water pump switch that stays lit until you turn it on. This seems counter intuitive to me and I'd expect the light to be off until you turn it on. Wondering if this is miswired in mine or if everyone's works that way?
Also, on Tuesday I plugged my shore line to power and the battery monitor reported 12.1. This afternoon (about two days later) I checked and it read 11.9. We've only gotten to take it out for one night so far, but after about an hour and a half tow (with 7 pin line powering) it had read 12.5 so I was expecting a higher reading today. Shouldn't shore power be charging? I'll be doing a longer tow tomorrow so it will be interesting to see what it reads afterwards.
Thanks, and Happy New Year!
E>
![](http://visitedstatesmap.com/image/ARLAMSTNTXsm.jpg)
2016 M@x S Sofitel - The T@bahoula
Shore power should charge the battery just as it did with the TV.
Check the fuse on the trailer battery and fuses inside the electric converter too. And prior to plugging the trailer into shore power make sure the ALDE unit is turned off as the fuses are very sensitive and might blow as they could see the incoming voltage from being plugged into shore power as a voltage surge and blow. One of my glass fuses blew similarly, but blew when a storm came through the area and the shore power voltage fluctuated, causing one glass fuse to blow.
Report back on what you find....
Are you perhaps running the 3way fridge on 12v while plugged into shore power? That might drain the battery. The converter might not be able to keep up with both charging the battery and running the fridge (switch the fridge to 12v only when driving).
Battery water topped off?
Also, check the fuses. Two in the fuse box, and one on the wire that connects to the positive on the battery.
Appreciate the advice.
E>
(Removed incorrect analysis concluded from incorrect information.)
Anyhow, home now. Going to bring it to the dealer tomorrow and see what they can make of it.
But the battery shutoff switch does need to be turned on for the electric converter in the trailer to charge up the trailer battery while on shore power. If you were running off of shore power and the battery switch happened to be turned off it would not be included in the circuit and thus would not be receiving a charge via the converter.
If you are not getting power "inside the trailer" with the battery switch in the off position and "while plugged into shore power" it sounds like someone incorrectly wired something up via the electric converter in the trailer. I'm wondering if the ground wire in the bench seat next to the Alde unit is unhooked as a bad or insufficient ground would cause your problem. And if the tow vehicle charges up the battery while running you obviously are okay on that end of the battery. I smell a bad ground or incorrect trailer wiring here and would be curious as to how long you've owned your trailer and had it in your possession before you started noticing this problem?
I would follow the battery shutoff wiring back into the trailer too as this sounds like the potential source of your problem. Which wire (+ or -) is hooked to this switch?
I appreciate the help.
E>
