Thanks
qhumberd
Moderator
Dump stations vs hook up re sewer use
i have watch many more "dump station use" videos than I ever imagined, or hoped, to view. How do these procedures differ from the regular use at a site with sewer hook up available?
  • jkjenn
    jkjenn Member Posts: 6,417
    The only difference is that you can connect the grey tank and leave it open while you camp with full hook-UPS. Otherwise, it's the same.
  • ChanW
    ChanW Member Posts: 3,165
    Is that the normal procedure? Leaving the gray valve open?
    I ask because I've wondered if it makes sense to be 'venting' the campsite's dump tank back through your hose through your tank and vent. There's no trap in between the CG's tank and the Tab.
    Does that matter?
  • Alan
    Alan Member Posts: 120
  • Michigan_Mike
    edited January 2016
    Does that matter?
    Watch the video for a great tip and "the best of both worlds!"
    https://youtu.be/dslcXoydeY4?t=18
  • Orygun
    Orygun Member Posts: 17
    I never leave the trap open. I let the tanks fills a bit, then dump them daily or every other day just like you would at a dump station. But I do stay connected, then you just have to turn a valve. Don't like to take the chance of noxious fumes entering my teeny trailer.
  • ChanW
    Mike, I'm thinking y you had something else in mind for that video? It's kind of short and sweet...
    Does that matter?
    https://youtu.be/jvm6bIGpWXc?t=5
  • jkjenn
    Does that matter?
    I have never had an issue. I did it for 5 days at Ridgway last fall. I only have an 11 gal gray tank, so it saves me constantly opening and closing.
  • Michigan_Mike
    Chan - for whatever reason the original link was omitted.   I cleaned up my original post and this was the video I intended to share.
  • ChanW
    Thanks Mike. That put the question (and answer) much more clearly. I thought there might be a 'stink' problem.
    The Tab's vent is low, doesn't have the advantage of coming out the roof, so the wrong wind direction might spoil the old singin'-around-the-campfire atmosphere, so to speak.
  • jkjenn
    Since I usually use risers there is a natural P trap. That's probably why I have never had an issue.
  • ChanW
    Yeah, that p-trap idea in the video is excellent.
