We are about to put on a hitch to our Lexus RX350 for our ordered T@B S. The videos suggest that the electric brakes are a choice. Being new to RVing, we are not sure whether this is needed or not. We need to make a decision soon, so any ideas, thoughts, or suggestions would be greatly appreciated!
0 ·
There is a removable handset that plugs into your cigarette plug in your tow vehicle that operates the brains of the brake controller bolted to the trailer tongue (and linked to the brakes and 7pin recepticle at the back of your your tow vehicle).
I had my dealer mount mine on my trailer tongue the day I picked up my T@B. I highly recommend this product. It is not cheap but it gets your trailer brakes working and as I say saves your tow vehicle from damage. It also means you can use multiple different tow vehicles to tow the t@b. Just unplug the handset from one tow vehicle and plug it into the cigarette plug in the second one and off you go. See photo.
South Carolina
Also, be sure your '7-pin connector' (coming out of the tow vehicle) is wired with heavy gauge wire for the 12v charging wire, and the ground wire. They should be minimum 10ga. (the higher the number, the smaller the wire). They should come (fused) directly from your tow-vehicle's battery/alternator.
The Tab electric system and charging system can draw a high amperage with the three way fridge, so you need heavy wire.
South Carolina
This video will give you an idea of what the Prodigy unit entails.....
Thanks for your response. We have a 2015 Lexus rx that thankfully had the 7 pin and had a plug in harness that was helpful getting the car ready for the hitch. We had a Prodigy installed on the trailer, so we did not have to go through the firewall. The car seems to be doing well pulling the trailer!
South Carolina
