Aloha! Wife and I first timers towing a trailer. We're picking up new T@b in Columbus, Ohio next July and traveling back to Newport, Oregon. Towing with 2015 Subaru Outback 4 cylinder. And for planning purposes , how many miles do you estimate making per day average?
                0 ·
Our biggest issue was the towing hitch, ball mount, or whatever you want to call it. The dealer installed one on the Subaru that dropped a couple of inches and it caused the camper to drag on the ground when entering or exiting a gas station or any other location where there's a fairly significant change in ground height. We also experienced a tremendous amount of trailer bobbing up and down on semi-rough roads. This scared the heck out of us! -- Good news: We solved this problem last week by purchasing a ball mount that doesn't drop down. It's parallel with the receiver ( I guess it's called). The camper sits up at a slight angle, but the Subaru's ride is significantly improved! -- Just a few words of wisdom!
The disadvantage, boon docking in July, would be no air conditioning - only the Fantastic fan. Your tow vehicle likely does't have a large enough alternator to handle keeping the fridge running on 12 volt, but we have found that using an ice chest in the car is good enough to keep some things cold for a trip.
For trip planning purposes you can use software on your computer. I use a MacBook and like Roadtrip Planner. I also use AllStays website for planning. It lists all of the truck stops, rest stops, Walmarts and campsites.
(formerly a 2013 T@B Q M@X); 2015 Jeep Sahara JKU (Max Tow)
Toronto ON Canada
However, in July, it will be hot and humid until you hit western Nebraska and then it will be just hot.
You could also check out the Good Sam RV Club. You can get discounts on some parks and discount fuel at Flying J/Pilot truck stops as well as discounts at Camping World. Good Sam also has a roadside assistance plan that is fairly inexpensive and it can include towing, flat tire repair of the trailer as well as your car.
Toronto ON Canada
Yes, and to save time, you don't have to dump your tanks every day or even hook up to water.
