Fuses
Alan
Member Posts: 120
i think the Alde fuse has blown. All thevlist I find call for a 20 amp for the pump. However there was a 15 amp in there. There are couple of 15s when none is called for. Any guidance? .
Yes, you are correct those are the Alde fuses. I think I'm trying to replace the circulating pump fuse.
Thanks, boo. It is important for you to know that you're dealing with a clumsy mechanical/electrical imbecile. When I removed what I thought was the guilty fuse I dropped it to the bottom of the fuse box...gone. So, I didn't even confirm that was blown ( not that I'd know how to do that). My wife, who is much smaller and agiler (that isn't a word, I know) was able to insert a 20 amp fuse in the empty slot. We are now waiting to see if the heat comes on. Sigh! This is all beyond my skill level
And the heat is still not coming on?
Aside from the fuses, there are two AC (mains) circuit breakers in my converter box - one is 15 amp and the other is 30 amp. I have three AC (mains) outlet boxes inside, plus one under the driver's side bench which the air conditioner plugs into plus an outlet outside on the passenger side for a total of five outlets. Can anyone advise which of the outlets are on the 15 amp circuit and which outlet/device is on the 30 amp circuit?Ray and Vida Barrick
(formerly a 2013 T@B Q M@X); 2015 Jeep Sahara JKU (Max Tow)
Toronto ON Canada
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
