Since you will experience some parasitic drain when not in use (e.g., via the USB ports, electronics, etc.) unless you have a means of isolating the battery you will want to as a bare bones minimum at least remove the battery fuse or install a battery on/off switch to eliminate any drain on the battery. Even when unhooked the battery will discharge some when sitting idle as this is a normal phenomenon.AustinRoamers said:I've read a lot of the posts on options for battery preservation. We are able to keep our T@B plugged into shore power when not in use. We plan to take her out about every 3 weeks. Is there a reason we shouldn't be plugged in when idle?
Here is a chart I found here in the forums that is very different than Michigan Mike posted above. Look how a reading of 12.1 appears in each chart. So, which is more accurate???
2016 T@B S Max, near Portland, OR
Photo Galleries www.pbase.com/jctangney
Battery Cycles at various battery DOD battery
mash2, thanks for the thorough explanation! So, based on your info, I will try to keep it above 12.1, whenever possible. I assume most of our trips will be a mixture of with and without hookups and rarely over 3-4 days with no hookups, so I should be fine. Again, I really do appreciate the info. BTW: I have already gotten my Battery Tender so that when I get home I will plug into shore power for a day or so to insure I am fully charged and then switch to the Battery Tender!
