Little Guy Visor on the T@B?
RZRBUG
Member Posts: 890
I have not seen either of these products, but since I would like a small visor (just over the door) on the T@B, why couldn't I adapt the LG one and use it? Since it already has a keder rail, seems all I'd need to do is make the tie-downs longer, which could be done with tent cord.
Anyone familiar with these products have any suggestions?
Seems reasonable to me that it would work.
Sterling, VA -
Awesome. Like to buy one. Hope Amazon carry the item.2015 S Sofitel, Austin/Houston
The only way to get the T@B visors is directly through either the Teardrop Shop or through PahaQue directly. They are custom made for each order and take some time to get, but I think they are worth it.
I love my Visor XL, takes all of five minutes to put up and does the job. Becky and I sat under our visor last night in the rain, stayed dry while enjoying a beer and listening to the sounds of the frogs in the woods.
Sterling, VA -
Thanks very much for sharing your wonderful experiences. We're new to RV and look forward to learn from you all on camping.2015 S Sofitel, Austin/Houston
Since I started this thread, I suppose I should tell you that I recently purchased the Visor XL. I experimented for about a year with a homemade awning (search Redneck Porch). Although it worked fine, it was a little cumbersome and took some time to put up. The XL works as well and provides just as much protection, not to mention how much better it looks. I must say, however, that five minutes beats my time considerably. Takes me about 20 minutes, including the guy lines.
Awesome, Larry!! We're really going to look like twins at the CRA and Tearstock!Verna, Columbus, IN
All about practice Larry. It took 45 minutes the first time I had a go at it. I have since changed out the guide wires to something that works well to me and gotten the technique down for getting the poles in, which is really the big thing when setting this thing up. Now it is worth it to set up every time I stop.
The awning, on the other hand, uhg!
Sterling, VA -
I probably will get silver color. How long does it take to setup? Any accessory that I also need to buy?2015 S Sofitel, Austin/Houston
Always wondered what it would be like to be a twin, Verna.
I thought I'd like to have white and red, but later thought it might be a little harder to keep clean.
Playc said:I probably will get silver color. How long does it take to setup? Any accessory that I also need to buy?
See above about the time. It comes with everything you need to set up.
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
