Hello.......I'm new to this forum and am very interested in purchasing the Little Guy T@B S Max in the near future. I currently own a 2014 Ford Edge SUV with the 3.5L V6 and 6 spd Select Shift Automatic Transmission. Does anyone use this same vehicle to tow their T@B's and if so have you had any issues at all especially in the mountains? I have never trailered anything larger than a smaller fishing boat and am trying to learn all I can before making the purchase.  Thanks!
                0 ·
South Carolina
I'd check with Ford on differences in the factory tow package to determine potential issues (sway control adjustment and stronger radiator might be necessary).
They should be able to let you know what it would take to upgrade.
I don't think the engine and transmission vary, so overheating seems to be biggest potential issue. The T@B is under 2,000 lab's so I would think that the sway control is probably less critical (but they could let you know).
The issue isn't with raw power, there is plenty of that. I tow with a 2.0 Escape which has less power than your's and it does fine in all terrain (I do have a factory installed tow package).
