Is this yellow or green?! At first I thought I had yellow antifreeze but since my reservoir sits underneath my large back cabinets, the light makes it questionable. Elsie told me "they use yellow" but I have no idea who fills them prior to delivery (couldn't get an answer from my dealer). Those who have green - is the green a darker color? Thanks --- Michele
The dealer doesn't put the Alde's glycol into the system. It's put in at the factory.
Elsie told me they use yellow (Century something) which is yellow. Guess I'll go with that.
Edit-Add: Everyone would actually find that helpful.
If you're unable to get hold of the above, you should use a 50:50 mix of ethylene glycol and water. Ethylene glycol (AKA monoethylene glycol, MEG and ethanediol) is an anti-freeze that's also used in car engines and is available from petrol stations, garages and car accessory stores in concentrated form or ready-mixed.
Do not mix anti-freeze containing silicates with anti-freeze containing non-silicate-treated OAT. When diluting concentrated glycol, make sure the water is clean and fresh, and ideally use distilled water.
Anti-freeze containing phosphates should only be mixed with distilled water.
2019 Honda Ridgeline, AWD, V6, 5,000 lbs towing capacity
Minnesota
Minnesota
That Alde branded stuff in the photo is NOT the right one!! That is poison.
2014 T@B CS Maxx
Martha Lake, WA
