We had them move the spare
Redufresne
Member Posts: 100
so that we can use the Yakima roof rack to hold other stuff. Here is a picture of what the guys a Beckley's did for us:
B@t T@b, the 2016 Max S Outback, pulled by Bane, the 2014 Honda Ridgeline.
What kind of tires do they put on the Outback? Nice setup vs. mounting on the side of the tongue.
J.D. & Sue
It's a heavier, slightly larger tire for off road. I don't know exactly what kind. They welded a tire mount to the tongue frame to make it work for us. We just didnt see the point of a rack that was taken up wholly by the spare, so we were pretty insistent. They were very accommodating at Beckley's in MD.B@t T@b, the 2016 Max S Outback, pulled by Bane, the 2014 Honda Ridgeline.
I really like the tire mount. Do you know if it is a standard product they welded onto the tongue, or something they fabricated?John and Henrietta, Late 2016 T@B S Max in Western New York
Beckley's did nice work there. That is a great location for the spare.
Sterling, VA -
They are General Tires. I think they are A/T Grabbers. I will check when I get home.DurangoTaB said:What kind of tires do they put on the Outback? Nice setup vs. mounting on the side of the tongue.
They fabricated some of it. You'd have to contact Beckley'sB@t T@b, the 2016 Max S Outback, pulled by Bane, the 2014 Honda Ridgeline.
Jenn...you're good! http://www.tirerack.com/tires/tires.jsp?tireMake=General&tireModel=Grabber+AT+2
J.D. & Sue
Those are they! 27x8.50x14DurangoTaB said:Jenn...you're good! http://www.tirerack.com/tires/tires.jsp?tireMake=General&tireModel=Grabber+AT+2
This *looks* like what Beckley's may have used. http://www.crofttrailer.com/stctm-croft-tongue-mount-spare-tire-carrier-weld-onJohn and Henrietta, Late 2016 T@B S Max in Western New York
Here's mine - bought at a marine dealer - It's what's on most boat trailers in my neck of the woods. I added a wood block to set it further out from the frame - allowed me to shift it back closer to the propane tub.
Pxlated's tire mount looks nice. We'll have the aluminum platform so I'm not sure if side mounting will work.
I did find a trailer place who will weld the mount on a la Redufresne, if I can get one somewhere.John and Henrietta, Late 2016 T@B S Max in Western New York -
Photomom, you could call Beckley's in Thurmont, Maryland, and ask them what they put on the T@b Outback for Randi and Rob Wall for the tongue mounted spare. Oh wait, maybe you already found it, I see above.B@t T@b, the 2016 Max S Outback, pulled by Bane, the 2014 Honda Ridgeline.
- 916 Introductions
- 72 Teardrop Groups & Links
