So my T@B is a 2005 and some of the items in it are getting pretty old.
The fan is one of those things and has quit working partly due to some previous owner wiring hacks.
Since the stock Northern Breeze fan is old and not very efficient we decided to upgrade.
After tons of reading we decided to go with the MaxxAir Deluxe 7500K:
http://www.amazon.com/Maxxair-7500K-MaxxFan-Remote-Control/dp/B002OW5JG2/ref=sr_1_2?ie=UTF8&qid=1458826413&sr=8-2&keywords=maxxair+maxxfanAll the reviews I've read are very positive so we pulled the trigger.
http://rvroadtrip.us/reviews/maxxfan.phpThe cool thing about this fan is that it has a rain sensor and will close if it starts to rain.
In addition, the way the hood works it works when it's closed!
It comes with a remote and an automatic thermostat that will turn the fan on at a certain preset temperature.
Hopefully I will have time this weekend to start installing it.
I can't wait!
The link I posted was not to show the price, but the unit itself.
Weight never crossed my mind but I'm sure it will be fine. I'll let you all know how it goes.
Please post some photos of the old fan removal and install of the new unit.
The install was super easy. The hardest part was getting the old fan out, but even this was very straightforward.
Haven't installed the interior beauty ring yet but I'll get to that soon.
Next up will be one of those Victron battery monitors.
Here's a photo of the vent installed:
Thanks EWizard - that is one sleek looking fan! Report back to us when you've used it a while. Some reviewers said it was a little noisy on the higher settings - let us know what you think.
Regarding the Vectron monitor, I just finished getting mine roughed-in. Because I have everything opened up, I'll be ordering the digital Alde controller from Elsi on Monday. Might as well get them all done at the same time. A few points to note:
I ran the phone cord from the shunt in the battery compartment to the interior of the cabin along the outside of the underbelly with the phone cord for the inverter and 12/3 cord for the inverter outlet. I simply drilled a 3/4" hole in the floor in front of the driver side tire wheel well. Luckily it came up in a perfect location to pull the wires. Covered the three wires with plastic loom and secured it to the underbelly with 1/2" plastic electrical conduit holders (used about 4). I then caulked the small opening in the floor with black silicone caulk. I'm just offering this alternative because I could not see how anyone could snake a cord through the center-front of the trailer, into the interior, around the shower, and then under the seat pedestal. If you can, then you are a better man than I.
I also had to remove the white plastic backplate behind the Television because there is not a clean shot straight down from the opening of the Alde controller. I needed to snake the fish tape to the left and then down into the pedestal area. The guys at LG appear to take pride in making wire holes just big enough for THEIR wires![:) :)](https://tab-rv.vanillacommunity.com/plugins/emojiextender/emoji/yahoo/smile.gif)
Central,Fl
2015 T@B Max-S
Will report back when I use it some more.
Hopefully it sucks down less energy than the old one.
I am looking at this fan as an upgrade on my T@B, but I park it in my garage and was not sure how much height it add and would it still fit thru the garage door. Could you please post how much taller is it than the factory fan? is the new fan taller than the vent pipe thru the roof and if so by how much? this would really help me out on pulling the trigger or not. Thanks!
Central,Fl
2015 T@B Max-S
2016 T@B S Max, near Portland, OR
Photo Galleries www.pbase.com/jctangney
Keep in mind this is for the 7500K model which is their top of the line fan. Not sure about the specs on their other fans.
Here's the inside shot (sorry for the huge picture).
Here's a [blurry] shot with the vent open all the way:
One more of the remote mounted. It actually has a holder that I Velcroed to the wall. The remote can be removed easily.
It was pricey, but if we got another T@B (400 maybe someday) we would get one again.
Sterling, VA
