Can anyone suggest a flat screen TV mount?
tabulous
Member Posts: 13
I own a 2008 T@B Dutchman and I am removing the small AC TV and replacing with a 16" flat screen AC/DC and will mount somewhere between left window and closet. I have seen many different wall mounts, some articulating and some not. Anyone installed a TV wall mount?
2008 T@B Dutchman, 2004 Hyundai Santa Fe, Grand Junction, CO.
"We Are T@Bulous!"
"We Are T@Bulous!"
Thanks ST_Bob! Those are some great choices. Of course, I will have to wait until my flat-screen arrives so that I can evaluate the mounting capability on the back of the unit.2008 T@B Dutchman, 2004 Hyundai Santa Fe, Grand Junction, CO.
"We Are T@Bulous!"
@tabulous Did you happen to find a mount you like? Mine seems to have broken on the way home (and broke the TV along with it.)
http://www.parts-express.com/dayton-audio-shadow-mount-lcdart-articulating-arm-tv-wall-mount-up-to-30-lcd--182-370
This is is the mount I installed to replace the factory mount. It works great. It's well constructed and was easy to install. The original mount kept coming loose and the television fell a couple of times. The tv still works though after I resoldered the antenna jack.2014 T@B-S
2019 Honda Ridgeline, AWD, V6, 5,000 lbs towing capacity
Minnesota1 -
Thanks! I think I found a similar one from Amazon.Spruce1 said:http://www.parts-express.com/dayton-audio-shadow-mount-lcdart-articulating-arm-tv-wall-mount-up-to-30-lcd--182-370
This is is the mount I installed to replace the factory mount. It works great. It's well constructed and was easy to install. The original mount kept coming loose and the television fell a couple of times. The tv still works though after I resoldered the antenna jack.2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
