PROPANE LEAK
CodeJunkie
Member Posts: 50
Noticed a strong rotten egg/sulfur smell near the battery/LP storage box; not really any odor inside the T@B. Found a leak at the LP connection where it attaches to the T@B, not at the tank connection (see pic below). I could actually feel and hear the hiss of "air" around the nut. I tried tightening the nut, but it seems very tight and wouldn't budge. So, I turned off the propane and disconnected from the tank. I am boondocking hundreds of miles from home base, now without fridge, cooktop, or heat. I can make-do OK for the time being. Anyone had a similar problem? Ideas? Fixes?
Debbie
2014 T@B S M@xx with wetbath, aka PopT@B, silver with black trim, TV 2002 Chevy Avalanche
"Take only pictures, leave only footprints."
Find some teflon tape (aka plumber's tape) and wrap the male threads twice. Try tightening the bolt again to see if that fixes the leak. Glad you found it when you did!2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)2
If the teflon tape doesn't work, try pipe thread sealant, if that doesn't work you may have a crack in the female fitting.The HobbiT@B, 2015-L, towed by a2014 RAM C/V0
You can check for leaks by slathering with soapy water - shouldn't see any bubbles.John and Henrietta, Late 2016 T@B S Max in Western New York1
^^^ both good suggestions!2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0
Here's what plumbers use....I may pick some up and keep it in my truck or T@B!
http://www.amazon.com/SEPTLS7478OZSNOOP-Snoop-leak-Detectors-8OZ-SNOOP/dp/B00H895GH8
J.D. & Sue
2 -
As far a as the nut being tight-- try loosening first, then tighten.0
