AC thermostat and some other small upgrades
Redufresne
Member Posts: 100
We will be camping again this weekend. I put in an AC thermostat so it will cool to a temperature instead of Just the high/low knob. Found that bad boy by searching AC on this site and up that thermostat popped! Thanks! Husband put in hooks to hold netting for shoes under Lagun. Also, hooks under back cabinets so other netting went there, making that space from cabinets to shelf much more useable now. Added another extender to black tank drain, as it was so hard to reach with the new aluminum boxes on the platform. Had to do some Dremel work to make a tiny knob so I could move the drain cap connector strap to the new end of the pipe. I'm getting good at that, having done it for the gray tank pipe previously! Still need to figure out blocking the drafts around AC cabinet - window sealer didn't stick well. I have the AC cover. But it has not yet been installed. I was going to put it up with dual lock velcro, but can only find the hook side of the dual lock! Maybe plumbers putty smoothed at interior gaps? I don't want anything too permanent. Oh, the fun we are having!
B@t T@b, the 2016 Max S Outback, pulled by Bane, the 2014 Honda Ridgeline.
The things you can do, add, or modify are endless :-)0
Yes, endless! And I just realized the dual lock is only one trip that sticks to itself. So i'll
try that tomorrow.B@t T@b, the 2016 Max S Outback, pulled by Bane, the 2014 Honda Ridgeline.1 -
We call that T@baddiction
or at least that's what the wife's been calling it we owned are unit for 3 months and 1st trip will be this weekend with all the mods. And it's a very long list can't even begin to list everything we've done. Greatful to all members of this forum that share experience and insights. Tony D
Central,Fl
2015 T@B Max-S0 -
Photos tomorrow, I promise!B@t T@b, the 2016 Max S Outback, pulled by Bane, the 2014 Honda Ridgeline.1
@ST_Bob. Thanks for scoop on dual lock. I finally figured it out. Will consider attaching tomorrow.B@t T@b, the 2016 Max S Outback, pulled by Bane, the 2014 Honda Ridgeline.0
@Redufresne I can't find the posting on this site for AC thermostat installation you mentioned.....
Well, it totally failed anyway and I returned it: http://www.amazon.com/Lux-Heating-Cooling-Programmable-Thermostat/dp/B000E7NYY8/ref=sr_1_12?ie=UTF8&qid=1462237367&sr=8-12&keywords=ac+thermostat
if you find one that works, please let me know.B@t T@b, the 2016 Max S Outback, pulled by Bane, the 2014 Honda Ridgeline.0 -
Good to know! Sorry I didn't work, it was a great idea.....
- 920 Introductions
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
- 54 üCamp Rally - News & Information
