All outlets are dead...Ideas?
We're on our first trip of the season in our new-last-summer S-Max.
Systems are fine except no power to any of our three electrical outlets. If the problem is in the fuse box, I don't see it. We're hooked up to campsite power and other electrical is fine.
Any ideas?
thank you!
Doug
Des Moines Iowa
2016 S Max Sofitel
  • Hans111Hans111 Member Posts: 47
    Doh!
    As soon as I posted, I got it figured out.
    A breaker in the power post.
    Little by little!
    Doug
    Des Moines Iowa
    2016 S Max Sofitel
    Glad you discovered the solution! Many people turn off the pole when unplugging. Probably unnecessary to do so, but I do it too. I was also going to suggest you find the outlet with the GFI test buttons on it. That is the GFI for all 110 outlets in the camper. If that is tripped, none of the outlets will work (in my T@B, your T@B could be different!).
  • USWildflowersUSWildflowers Member Posts: 177
    Yeah, the GFI tripped on mine this week, and I had to crawl under the bed while DW was asleep to reset it so I could have my coffee whilst she slept.
    Priorities, USWildflowers!! Must.have.coffee.
