Was up at the Phoenix dealer yesterday (getting closer to putting in my order!). Had a question about those of you who have put a decal on the back personalizing your T@B. Did I read somewhere that the factory will do this for you when you order? Or has everyone done it themselves? If you had to do it yourself where did you get it done and how difficult was it to put on? I'm hoping the factory can do it but now I can't remember. I also tried to search for photos of those who have done this but didn't remember which heading to look under. Is there a particular area to search? Thanks! Michele
0 ·
I ordered my lettering from buildasign.com. You can customize the font, size and color. Application instructions are included. Getting it centered, leveled, and applied without wrinkles is a little tricky. I did some measuring and marking with a graphite pencil that could easily be erased after application. If you can find a shop that it will do it for you, it will go much better, although it will probably be a bit more costly. Most areas have shops that can design and apply these. Yellow Pages under automotive or truck should turn some up.
Happy Trails Y'all
Thanks. The ones in front came from gaspumpheaven.com The back one is a truck rear window that I cut to size. I cut out parts of the leftover and used them elsewhere, mostly inside. I forgot the site, but I seem to recall several places having them.
Happy Trails Y'all
T@B CS "The Bedbug"Anyway, thanks to all for their input. I'll talk to the dealer when the time comes about possibly sending the "signature" electronically to the factory. Or will also look into having it done on one of the sites that others have suggested. But I'll for sure need to have someone else put it on - I wouldn't want to mess it up!
T@B CS "The Bedbug"I ordered the T@B without any logos. The dealer installed my decal.
