Hooking the chains to the hitch
Photomom
Member Posts: 2,217
The hooks on the T@B chains would not physically fit on the loops of my hitch far enough so the gates could close. The dealer added these link things and secured the chain hooks to them. Is this kosher?
I am really surprised they don't fit. I would probably replace the chains with something that will fit.
Those are called "quick links" and are just fine to use. Run ur chains through them, take up the slack, clip the chain end back to itself. Done. A lot of us use them2015 CS. Ford f150 v8. Southern california2
Should be fine as long as the quick links are rated the same or higher than your safety chains as far as load capacity is concerned.The HobbiT@B, 2015-L, towed by a2014 RAM C/V4
The quick links I had were rated for 5,000 lbs, so if yours have that weight range, you are good to go. (My original chains were too short, so the links worked until I found chains I liked.)Verna, Columbus, IN
He brought them out from the shop, so who knows. I may run out to Home Depot and get some that are labeled.John and Henrietta, Late 2016 T@B S Max in Western New York0
We had same problem but solved by sliding chain end all the way through the provided hole and then clipping it to itself. I seem to be the only one of us who can get them to fit through the spaces, so B@thusband cannot camp without me!B@t T@b, the 2016 Max S Outback, pulled by Bane, the 2014 Honda Ridgeline.2
Redufresne I do it the same way with my Ridgeline and now my Acura MDX0
With my 2009 Sport Trac I have really "fat" chain loops also. I bought new larger hooks for the end of the chains.Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL1 -
Photomom
The chain is high-strength chain, and those quick links are not, so you need to go up a size for the quick link, to match the rating. I think the chain is 1/4" so you'll need 3/8" links.
Check your length if you do what Redufresne did, so when you're turning tight they aren't too short.Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya1 -
I did get some 3/8" stainless steel links that are rated for 3600 pounds. I feel much better about those. They are large enough to pass the chain thru and connect back to itself. The chains are about a foot too long for my setup. The dealer had shortened the chains by twisting which I know is a Bad Thing.
John and Henrietta, Late 2016 T@B S Max in Western New York0 -
Photomom, My chains were also too long for my "72 Chevy P/U. Take the nuts holding the chains [there are 2] off from underneath where they attach to the trailer, shorten the chains to the desired length, put the chains back on the bolts, secure the nuts [with the lock washers] , and make sure the cable for the brake is not too long to actuate if needed. I hope this helps!2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf0 -
I was just looking at my chains and i have those same connections. I have no way to know the weight rating, but in looking at the same sized ones in the store they are under rated for my trailer. I'm going to attempt to replace them with hooks. The last shop I took my trailer too was not a fan of this setup, and I have had issues where the chains get stuck inside the link and it can be really tough to get them un-stuck.0
I use quick links at the other end of the chain: I cut a single link off the end of each chain which I used to permanently mount a quick link on each side:
Now I can adjust the length of the chains
Roger and Sue Hill | 2020 T@B400 Boondock (Cryst@bel) | 2022 Land Rover Defender 110 - P400 | San Juan Island, WA1 -
@TowingTipsy There are some good reference materials in the group about appropriate chains and hooks, etc. This thread has a link to a Purdue University brochure about safe towing practices, and there is a screen shot to help you determine the chain strength.The Purdue Document. Page 42 starts the conversation about safety chains and the various rated hooks and attachments.
I also slide my chains through and attach to itself
For my previous Little Guy 6 wide I had a new clip installed to end of the chain that would clip right onto the hitch0 -
My T400BD chains as supplied by NuCamp were lightweight and the hooks were too small to fit on my TV’s hitch loops. I replaced the chains and hooks with heavier duty versions. That also gave me a chance to cut the chains to the right length so I don’t have to twist them to fit - just cross them once and snap the hooks on. Much faster!
